Question about ITT Night Quest 160 Monocular
On_Off switch getting unreliable
Switch sometimes does not lock in "ON" position
What is an estimated cost of repair?
When I set my car alarm it don't beep. I goes to quit mode..how do I fix this
Car alarm fitted to a watch?
Depends on whether it is an aftermarket alarm or OE and what sort of quality it is.
Low cost car alarms are notoriously unreliable and short-lived so replacement is often the only cure, though one big problem with aftermarket alarms of all qualities is the cheap and nasty way lots of them are installed; thrown in, badly sited and wired.
OE alarms are relatively reliable and failure to operate is usually the peripherals, such as door, bonnet or boot switches which are often buried in the catches or multiway connectors into the doors. Pre remote central locking sometimes a complicated switch connected to the door lock would be used.
Jun 26, 2015 | Watches
1998 Volvo V70 ignition switch turn 360 degrees
This is the problem with the ignition switch.
The lock cylinder into which the key is inserted, and the electronic switch that sits just behind the lock cylinder are not in proper alignment with each other.
Probably before you plan to replace the switch you can take the switch of and put it back in, many a times that will fix the alignment issue.
Thanks
Kevin
May 15, 2009 | 1998 Volvo V70
How do I program fob for mabilu maxx 2005
You have to go to a Chevy dealer. They have a hand-held computer they plug into your car to get it into programming mode. Probably cost $50-$60. Call them for an estimate.
Feb 15, 2015 | 2005 Chevrolet Malibu
Code P0706 transmission control module repair cost
You just don't throw a part on, If the problem is the transmission range selector switch (not the control module) the cost to repair will be around $250.00
P0706 AUDI - Transmission Range Sensor Circuit Range Performance
Possible causes- Open or short park/neutral position switch circuit
- Poor park/neutral position switch circuit connection
- Misadjusted park/neutral position switch
- Park/neutral position switch may be faulty
When is the code detected?The transmission range switch detects the selector lever position and sends a signal to the TCM.
Sep 18, 2012 | 2006 Audi A4
I own a 2005 Chevy Equinox with 83,000 miles. It has decided to just not start and their is a lock on the dashboard. Took it to the Chevy Dealer repair the guy stated it could be the ignition switch, it...
this is a common problem with the new Chevy ignitions --- sometimes it is the ignition switch and sometimes it is the microchip inside the key itself. your best and cheapest way to get this fixed is to call a automotive locksmith and have them come out to your vehicle and determine if it is the key or the switch,,, either way it will only take 30 minutes to change out the ignition - or 10 minutes to re-program the key to the car. on the low end it will cost you 85 dollars -- on the high end it should not be more then 145 dollars ( this is with the new switch ).
c...
Jan 23, 2011 | 2005 Chevrolet Equinox
Its ok, to buy 1998 ford taurus wagon, 185 000 km
The 1998 Ford Taurus is a pretty reliable vehicle. Occasional problems on this vehicle are failure of the Camshaft Position Sensor and Actuator; Restricted EGR passages, 3.0L VIN S only; the Differential Pressure Feedback EGR (DPFE) Sensor; the Powertrain Control Module (PCM); and the Secondary Air Injection (SAI) Pump. The cost to repair the Camshaft Position Sensor and Actuator is estimated at $210.00 for parts and $65.00 for labor. The cost to clean out the restricted EGR passages is estimated at $5.00 for parts and $78.00 for labor. The cost to repair the DPFE Sensor is estimated at $76.00 for parts and $32.50 for labor. The cost to repair the PCM is estimated at $320.00 for parts and $65.00 for labor. The cost to repair the SAI Pump is estimated at $200.00 for parts and $52.00 for labor. Other problems on this vehicle are failure of the Transmission Range (TR) Sensor and the Door Ajar Switches. The symptoms associated with failure of the TR Sensor are loss of sound from the radio, loss of power window operation and loss of power steering operation when the car is shifted from park to reverse and/or drive. The cost to repair the TR Sensor is estimated at $40.00 for parts and $39.00 for labor. The cost to repair the Door Ajar Switches is estimated at $22.00 for parts and $45.50 for labor per door and can range from one to four doors. All prices are estimates based on $65 per flat rate hour and do not include diagnostic time or any applicable sales tax. I would advise you to have the car looked at by a trusted mechanic. With 115,000 miles on the odometer it can have some of these problems which are not severe. The money you spend to have it gone over by an expert will be money well spent.
Nov 21, 2010 | 1998 Ford Taurus
HOW MUCH DOES IT COST TO REPAIR A IGNITION SWITCH FOR A 1991 Dodge Spirit on average
Flat rates can vary from $70 an flat rate hr. to $125 per flat rate hour depending on the state that you live in; however, a flat rate hr is the time that is allowed for the repair. That job should be rated at about 1 1/2 hr +/- an hr. to complete plus the cost of the part. Whatever the flat rate would cost...no matter if the mechanic takes 5 hrs, the cost should not exceed whatever the flat rate has been estimated to be, so get the estimate first before having the work done.
Feb 10, 2010 | 1991 Dodge Spirit
Top right slider button won't slide to "picture" will only take pictures, and won't take videos also, the right side faceplate came off because both screws fell out.
This is a very easy fix, Recommend first calling 1-800-OK-CANON to get an estimate for their repair. It really should not be costly at all to repair due to the ease of the repair.
But, if they seem unreasonable in their estimate, you'll need to move the back face plate backward just enough so that you can align the slide button with its inner switch. Just remove the screws (keeping track of where they go) along the perimeter of the back faceplate. Using your fingers only, gently pry the plate back a small amount sufficient enough that you can move the switch to its other position. Reseat the back and see if the switch moves freely. Then try out the camera, and reseat the screws.
If you don't feel comfortable doing the above, find a friend who is.
Jan 15, 2010 | Canon PowerShot SD790 IS Digital Camera
It displays nd and nothing happens. Sometimes says cd and nada.
This a popular laser problem, if in warrantee, take it in for service. If not warrantee, get an estimate for replacing the laser assembly. You don't want to find it costing more than it does to replace it.
Jul 20, 2009 | RCA RCD160 Radio/CD Boombox
Panasonic DMC-FZ30 does not power up
remove memory card then try also refix batery and clean dust form it.
Mar 18, 2009 | Panasonic Lumix DMC-FZ30 Digital Camera
ITT Night Quest 160 Monocular Logo
41 people viewed this question
Top ITT Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an ITT Optic Expert? Answer questions, earn points and help others
