Question about HP Pavilion dv6000z Notebook
Reading a dvd in my lab top
I bought a Toshiba V-VR7KC to copy my old HI8 tapes to. I put it on dvd and it will play on the dvd player but will not read it on my lab top. Help
Try downloading some codecs is because the computer is new an doesnt have anything installed yet
Posted on Dec 17, 2008
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have two Toshiba DVD players -- a D-VR7KC and a SD-430VSC. Which is the older model of the two?
The D-VR7KC is a 2009 model. The SD-430VSC is older, probably close to 2001 time frame.
Mar 14, 2011 | Televison & Video
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
Nov 24, 2010 | Sony Handycam CCD-TRV81 Camcorder
Can't see how to play Hi8 tapes on this Sony dcr-trv340e pal camera
It's a Digital Hi8. Your tapes are Analog.
But it should play Analog also.
In the menu play with "PB Mode" settings.
Apr 14, 2009 | Cameras
DVD Computer Compatibility (Toshiba DVD/VHS Recorder D-VR7KC
are you formatting the dvd in the universally accepted, video mode or the incorrect VR mode?
Nov 23, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
MY SONY DCR-TRV140E WILL NOT PLAYBACK MY OLD VIDEO8 (PAL8) TAPES?
Vista should be able to download this without any issues as it already includes the drivers. i was able to do this with my sony dcr-trv250 painlessly over the ieee-1394 (firewire) port using the DVD capturing bloat-ware (Ulead DVD creater) Toshiba had already installed for me. My toshiba satellite is running Vista Home Premium.
as regards analog hi8 playback, the product manual for the 250 says that this is NOT supported, i.e., it CANNOT play back analog hi8 tapes. Also, i wonder if PAL would be supported here in the US (assuming you're in the US, of course). I would expect only NTSC support. but it's a moot issue, since it doesn't play analog
Oct 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
HP Pavilion dv6000z Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
