When ever try to use TrekStor DataStation External Hard Drive with my desktop PC (Windows XP), it shows error. Device has malfunctioned. On the other hand it works fine with my laptop (Windows XP). Can't understand, what is wrong?
  • 3 Answers
Well try running install new hard ware! xp is really propritory !!l it doent like to be put on different machines because it wants oem ## an i think it notes ur machine id # an when u move it to different machine it dont work!i move hard drives around from several machines! an it seems if its xp u have to reinstall xp on the new machine!
if its melinum or 2000 u have no problem! xp is a weird animal! well good luck an merry christmas!
dr fred!
Posted on Dec 17, 2008
Trekstor external hard drive (DSMNU-S-JM-a) is on (blue light) but the device no longer shows up on the computer. Can't be accessed.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
External Hard Drive Recovery Software
Sep 11, 2012 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5"
Hello
You need to understand that a hard drive is very similar to glass, if you drop it, its done for, and it breaks.
contact a data recovery service if you had something of importance in the drive, you will not be able to recover anything out from it yourself if you really dropped it.
they break, they can break even if the case falls over on it self on the table.
let me know if you have any other questions.
Thanks.
Ekse
Feb 04, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I dropped my TrekStor DataStation maxi g.u - 3.5" External Hard Drive 1TB & USB 2.0 on the floor. When I turn it on the light illuminates however when I plug it into my computer it doesn't even...
Mechanical damage. Last possibility to retrieve the data on it: open the case, extract the hard disk, put it in a desktop and try to access it in there. If even this fails then it's dead, junk it.
Feb 04, 2011 | Trekstor 88470 DataStation duo w.u 1TB...
Good day, I cannot access my TrekStor external hard drive. Is there a way I can get it to work without formatting it and losing the data? I am running Windows 7. Kind Regards, Dries
Hi AHPretorius:
Do you have access to a Windows XP machine that you can try to use the drive with? Maybe a friend's computer? I would try using it with such a system and run chkdsk on the drive to make sure that the partition is healthy; otherwise, you might want to buy the DiskInternals program that may be able to help you revive the partition.
http://www.diskinternals.com/partition-recovery/
Please feel free to ask follow-up questions in a reply here.
Thanks for using FixYa and Happy New Year
Jan 07, 2011 | Trekstor Datastation maxi t.uch 500GB 500...
My 750GB TrekStor external HDD failed. The light at the front of the device went from BLUE to RED and the machine seems to start to boot up the clicks a few times and then nothing. I cannot view the...
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 25, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
I have a external Trekstor DataStation maxi 500 Gb hard drive. I now have encountered a constant red light and when this happens the drive is not visible in Explorer. When I turn off the power and then...
At the least, the device is "unreliable", and it would be wise to replace it, either by exercising the warranty (if the warranty still is valid), or by opening the enclosure, removing the disk-drive, buying a new (and compatible) disk-drive, inserting the new disk-drive, and closing-up the enclosure, to create a "new" external storage-device.
Sep 18, 2010 | Trekstor Datastation maxi t.u SATA 500 GB...
Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
