Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Sta-rite pool heater SR333LP
I changed the thermostat on this last year. about 6 months later when the heater is turned on for the spa and temp set say at 100 (water temp about 85) the flame lights up and stays on for a short time then goes out. a few minutes later it comes back on. the heating process takes very long. occasionally it stays off until I turn it off complete and then turn it back on again. what do you think is wrong? would this possibly be the thermostat again? thank you, Mark Severino Arizona
  • Iain J May 07, 2009
    Same Problem.
    Board fault shows as HLS - replaced HLS but same problem. Thermal governor also changed. HLS Sersor does get hot, but there is adequate flow of water through the system - could it be the bypass valve ?
  • Anonymous Mar 21, 2014
    When I turn the electric pool heater on, the fan starts and then goes off in about five minutes. Then it cycles back on but the heat doesn't seem to change.
  • 22 Answers
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Posted on Dec 21, 2008
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
Can't change temperatures
need new control board check underneath for mice that wrecked wires
Sep 23, 2014 | Sta Rite Sr333lp - Max E Therm - Pool &...
Water Isnt Getting Hot
Could be that the plumbing got clogged while the system was idle
May 13, 2013 | Sta Rite Pool & Spa
My Sta Rite SR333LP Pool Heater is leaking by the inlet valve area
check gas pressure if low it over heated if ok heat exchange is going check chemistry
Mar 25, 2013 | Sta Rite Pool & Spa
R8 Error
dont know what heater yuo got may be a board or temp sensor also post if automatic control
Sep 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Pool heater not working
sounds like it is not getting enough water flow. Check to see that there is water going out of the heater. Here is a site you can check trouble shooting guide.
Feb 21, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
841 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
