I set the machine to do a quick wash at 40degrees, delaying the start by 8 hours so it would be just finished when I got home from work. But it hadn't started when I got home. It was showing E90 error message & lots of the lights were flashing. I didn't notice it doing this when I set it in the morning, but can't be sure. I can turn it off but every time I turn it back on the E90 message comes back & more flashing lights.
To be specific - the E90 code, the start/pause, the prewash & rinse+ lights all flash on & off. The 900 spin light & door light (green) both stay on.
SOURCE: Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
SOURCE: Hi!
I've had the same problem. I removed the top lit and found some pressure
transmitter and a pressure switch. I suspect that the pressure
transmitter is use for measuring the waterlevel in the machine. I think
the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few
times on the transmitter. After doing this the machine washes without a
problem since then.
Hope it helps for you.
