Question about Honeywell Heating & Cooling
I have an existing 3 wire honeywell room stat on a conventional ch system which has gone faulty. I have bought a honeywell DT200 to replace it but this looks like it only takes 2 wires. Can I use this stat as a replacement? If so how do I wire it and what do I do with the spare wire?
  • nodga Dec 16, 2008
    Hi ken, the wires I have are 1 x red, 1 x blue & 1 x yellow.
  • 306 Answers
Hook up the Red wire to R on the t-stat and the White wire on the W just cut the wire flush with the insulation and leave it un hooked. If those are not the color get back with me. ken
Posted on Dec 16, 2008
  • Ken Bledsoe Dec 17, 2008
    Take the Red and go to R on t-stat. Then take the blue and hook it to W. Try to turn on furnace if it works good. If it don't disconnect the blue and hook up the yellow in it's place.
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
DT200 Problems
Possibles are:
1. Heating system not powerful enough to get temp to 21 C. How high does it get if you set it to 23 C?
2. Hysteresis in DT200 set too wide? Adjust it to 0.5 or 1 C and retry.
3. Calibration error (ie you're using an independant thermometer to read the actual temperature, whereas the DT200 "thinks" it has reached 21 C. Is there a symbol on the DT200 which corresponds to a 'call for heat'?
Feb 08, 2013 | Honeywell Heating & Cooling
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Wiring honeywell DT200(T6620B)
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Apr 11, 2009 | Honeywell Programmable Thermostat Heater
Replacing old honeywell thermostat with digital model
Thought I could help but ?????? Not with ABC??/ DO you have any desinations on either thermostat that is Y G R W? Is this a mobile home thermostat?
Mar 21, 2009 | Honeywell Electrical Supplies
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring honeywell digital stat
Hello davem1952,
The way you wire it will depend on how the other end of your three wires are wired into your heating system. This link http://www51.honeywell.com/pacific/common/documents/DT200_Specifications.pdf
shows the various methods for wiring it and take into account the type of setup you are dealing with. You'll need to find the wiring detail ( last page) that corresponds to your setup..
Hope this helps..
Reagrds,
Rick
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
126 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
