Question about Concept CC-452 Car Audio Amplifier
No Output + Burned Transistor and something else...
Hi people, bought a Concept Amp. CD-810 class-D monobloc, connected and everythings was working fine... using it at very low volume so didnt notice there was no bass coming out, so when i noticed that i checked the fuses, and all fuses were gone (3x30A) so tried to replace them, but when i was trying that the fuses when sparking, i was strange cause i guess theres was a short but didnt have that in mind that moment (dunno wut i was thinking), so i unplugged the ground and connected the fuses and reconnected everything, when i turned it on, it blew up, so opened the amp and noticed that theres was a burned transistor (IRFP064N/mosfet), so bought that one and replaced and checked the circuit around for continuity anyway a friend told me that continuity not always means its ok, maybe theres short somewhere, anyway i got correct signal or well thats wut i thought, so replaced the transistor and tried again but it fried the same one, and these time none of the fuses where gone so im confused why the fuses wasnt working at all or maybe the short is in the fuses circuit?? im not a expert but learning jeje ;) All solutions, ideas or comments are very welcome. Regards
    Novelist:
    Champion:
  • 218 Answers
Depending on which circuit the IRFP064N/mosfet was in then you either have a blown output section and you will need to look at the other mosfet's that work with the one you replaced or if it is in the power supply area then you will need to check the other mosfet's that work with it in the power supply. Of course you will have to test all the driving circuitry that is associated with either output or power supply, which ever is involved and be sure that the driving voltages are correct. Of course, in the power supply it would be a high frequency square wave of about 50% duty cycle. A schematic would probably be of great help. Good luck.
Posted on Mar 23, 2007
I need some help hooking up an amp, tv, and xbox 360 together please! I have a Toshiba 46g310u TV and Xbox 360 already hooked up together using an HDMI cable. I just bought a Yamaha R-S300 amplifier,...
Many TVs have to have the optical output enabled in a set-up menu. Do you see red when the connector is disconnected (which doesn't necessarily mean that it is active, just that it is 'ON').
Have you checked the amplifier to insure that the input is working by connecting something else directly up to it? Can you test the TOSLINK converter by plugging the output into something else to determine where the problem lies. I still suspect it is in the menus of the TV.
Sep 10, 2013 | Toshiba 46G310U LCD TV
Marantz audio amp. How to set quiescent current on output transistors
Hi, quiescent current is set with a diode string located far away from the output transistor high miller compensation cap values used, quasi-complementary (of course), lots of non-linear, single-transistor gain stages here and there.
That's all i can remember about it...
Take care
Jul 23, 2010 | Audio Players & Recorders
Burned ower
Check for shorted speaker wire to car body. Amp will blow if output is shorted. Often times the speakers overheat from amp being clipped. This causes voice coils to swell and short against magnet causing amp to blow
Apr 21, 2009 | Car Audio & Video
I have a fosgate 301x with power to the amp but none coming out
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure.
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
Seems as you have blown an output. Seek repairs.
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
No picture
get a hold of concept via there web site and they should be able to help you with a local repair place or at least you can send it to them and have it repaired.
Apr 13, 2008 | Concept CM-1100DR 11.2 in. Car Monitor
Concept CC-452 Car Audio Amplifier Logo
259 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
