Question about HP Photosmart C3180 All-In-One InkJet Printer
WHEN I PRINT ON THE INTERNET ONLY, BOLD AND COLOR ITEMS WILL NOT PRINT. I HAVE A RECENT COLOR PRINT CARTIAGE IN MY PRINTER. WHAT SETTING DO I NEED TO CHANGE? beautywork@bellsouth.net
    Problem Solver:
  • 8 Answers
You should go to properties click on colour and untick gray scale
Posted on Jan 19, 2010
I just bought ink cartiages and im trying to print, but the color ink is printing in dashes, I dont know why, its a new cartriage and the black ink prints fine.
It sounds like some of the nozzles on your printhead are not printing.
You can check this by going to the maintenance tab in the printer driver folder for your printer.
The `nozzle check' shows you a grid pattern, and you can tell which colors are not printing correctly. There is a cleaning utility in the maintenance area as well. You should see an improvement with each cleaning. If you don't, stop using the cleaning utility, it will just waste ink.
You can try changing the ink tank, but the problem is usually a clogged printhead. The printhead is available as a user replaceable item, but can be a costly gamble. It is best looked at by a trained tech.
I service these machines, and can tell you, the number one issue with print problems is refilled ink.
Sep 20, 2010 | Canon Pixma MP450 All-In-One InkJet...
Why wont the print when you put a new color
check the cartridge expiration date, and be sure that it is genuine
Mar 22, 2010 | HP DeskJet 2600 InkJet Printer
Can't print
Weather you use color or not the system is tied togeather to use them both. A laser printer however would have been the best choice for you if you did not want color. However weather you use color or not the printhead in this unit is daisy chained thus the printer will not start without the color cartridge due to print head damage that can be caused by a dry print head.
If both cartridges are empty its because you have used color at one point.
Thanks please do use the thumbs above to vote on this solution. Also please leave feedback
Feb 18, 2010 | HP PSC 750 All-In-One InkJet Printer
No red color printing
Possible nozzle blockage, usually solved by physically squirting cleaning fluid into nozzle and letting soak for a while.
Printers are so cheap nowadays perhaps it might be worthwhile investing in something new!
May 27, 2009 | Office Equipment & Supplies
HP Color Laserjet 2605:new magenta cartiage, however the print looks orange not red. Any suggestion? I also ran the clean cartiage utility on the printer with no success.
Hello sir;As you discript seem like no cyan( blue), why don't make a color chart print out, it will tell you what color missing.
Apr 22, 2009 | Office Equipment & Supplies
Bold not printing "bold"
Please check with wordpad, if it prints proper
  • if yes only problem is with ms word, uninstall MS office 2003, clean registry using any good registery cleaner, then reinstall.
  • if not, the problem is with windows or printer--> unistall windows fonts, reinstall them.
  • uninstall printer, restart system, reinstall printer
Hope it will work, if not please feel free to contact back.
Zulfikar Ali
ali_zulfikar@yahoo.com
Mar 05, 2009 | Microsoft Office Outlook 2003 for PC
PRINTING IS SMEARY AND NOISY
If there is a clicking noise as the printer is printing then most likely the fuser film has torn. The fuser film is part of the fuser unit. This item is best replaced by a technician.
Have you found pieces of film like material around the printer paper exit? It is most likely a dark grey color.
Oct 13, 2008 | HP Color LaserJet 2600n Printer
Epson stylus cx2800 printing
have you try to use the clean utility in mainteance you can find this utlity
Mar 11, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
Ink cartiage wont work
I HAVE THE SAME PROBLEM. tried all the print solutions. Some of these units are not compatible with all OS. After do the obvious clean nosel stuff several times you may want to remove cart. and clean contacts with a clean pencil eraser, warm water and then dry completely. It didn't work for me but..... Alternative is to by a Cannon.
Dec 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
