Question about Dryers
No heat my gas dryer runs but no heat whirlpool ultimatecare dryer runs but no heat
  • xroof Dec 16, 2008
    IT HAS AN IGNITER NOT A GLOW PLUG OR IS THAT WHAT THEY CALL IT
    Novelist:
  • 161 Answers
Check the glow plug.
Take off the bottom front panel, push the start button and look for a red glow. This glow plug is about the size of your little finger and is hard to see when it's off but you will see a red glow if it's working. No glow, replace the glow plug.
If it glows for a few seconds then goes out then the solenoids on the gas valve should be checked with an OHM meter.
Posted on Dec 16, 2008
  • Ron Buice
    Ron Buice Dec 17, 2008
    Yes, if you look underneath while you press the start and don't see anything happening then replace the igniter.
My whirlpool cabrio gas dryer it runs but no heat
Pilot light lit? Try running a pipecleaner through the tiny hole where the gas comes from the line.
Dec 16, 2014 | Whirlpool Dryers
I have a whirlpool LGR4364JQ1 DRYER AND IT IS NOT HEATING UP WILL JUST KEEP RUNNING
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Whirlpool LGR4634J Gas Dryer
Whirlpool dryer runs but does not heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer mod.yleq5000pwo runs but won't heat
heatman101
Aug 21, 2010 | Whirlpool Dryers
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool LER4634E2 is running and will not dry? is it the heating element? how expensive are these? I bought this used. :(
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Dryers
Whirlpool gas dryer no heat
The problem is probably with the ignitor...these are very fragile and burn out easily or crack...
Replace it and you will be working again...
Here is a tip on how to fins the part online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Mar 04, 2010 | Whirlpool LGR5636L Gas Dryer
Does not run or heat
check the high limit cutoff stat and if you see the igtn glow red and a click after the problem is in the gas valve
Sep 03, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
144 people viewed this question
Top Dryers Experts
