Question about Motorola Mobility H500 Headset
Bluetooth Handsfree earpiece
I disconnected my bluetooth earpiece due to it was calling people on its own. But now I would like to try setting it up again and I can remember the PIN #. Apprently I set one up when I first set it up. With out the PIN it will not Bond any suggestions. Thank you, Kerry
Posted on Mar 23, 2007
When I try to pair my bluetooth to my phone it askes me for a password and i dont know what the password is. I have tried 0000 and every other possible combo i could think of.
Make sure you're trying to do it correctly. Also that you are indeed selecting the correct earbud. While the earpiece is off.. press and hold the 'Call' button for ~10sec.. it should start blinking two colors. After that you have about a minute to go to your phone, turn on bluetooth and search for the earpiece. The passcode should be 0000. If all else fails, clear your Bluetooth list in the phone completely shut it down and pull the battery. Try to turn it on without the battery (this makes sure it has been discharged completely) then replace the battery and boot her back up. Hold the call button on the earpiece until it blinks red and blue.. try to pair them again the the 0000 passcode.
Best of luck.
Mar 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a 2 year old Sony Ericsson K550i phone which performed very well until I set it up for Bluetooth handsfree use in my car. Since then the microphone & ear piece have ceased to work & I can...
I think the bluetooth set up is not the problem.might be your earpiece not work.we can test by your phone stick. the way is: move right then press * move left twice than press * move left then press *.it must fast,if it work on your phone display show:Service info,Service setting,Service test,Text label.choose service test to make sure your problem.
May 24, 2010 | Sony Ericsson K550i Cellular Phone
My bluetooth can't connect
Make sure your earpiece is compatible with your phone.
1. Charge your earpiece.
2. Go into the menu on your phone.
3. Go into Settings.
4. Go into Connection.
5. Select Bluetooth.
6. Choose Handsfree.
7. You will either see Motorola H500 listed (if you previously synched) or you will have to choose [Look For Devices].
8. While it is looking for devices, hold down the "Call" button on your H500 (it should have a phone icon on it) for two to three seconds and then let go.
9. Your phone will tell you when it has connected to your headset. The reset/bond code is standard for most Motorola phones: 0000
Mar 08, 2010 | Lands Phones
Earpiece won't link to phone anymore
Hi Josh,
there may be a battery or an internal antenna failure on your headset.
You might try re-pairing the devices if you can.
Jan 08, 2010 | Motorola Mobility H700 Wireless Headset
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth connects to LG Vu phone but does not work
I would suggest taking the battery out when the phone is powered on. Replace the battery and try to re-pair the set.
If that doesn't work, then its likely the bluetooth module in your phone is broken. You can validate this by pairing the bluetooth with another handset.
Jun 30, 2009 | LG Shine CU720 Cellular Phone
Placing a call via Buletooth
You can place a call by pressing on your bluetooth it will say "please choose a command" then say "call erica" and it will confirm with "did you say call erica?" and say yes. Remember to speak clearly. You can also do this manually by simply going to your contacts and dialing who you want to speak to.
Mar 18, 2009 | Nokia 2760 Cellular Phone
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 30, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Motorola Mobility H500 Headset Logo
77 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
