Hp laptop my hp dv 8000 laptop wont power up all that happens is the fan spins and the quick player lights are on is it the motherborad?
  • oloo May 11, 2010
    Could be. But it could also be the HD, the graphics system, The CPU, the RAM or a loose connection somewhere.
    Any other symptoms? Do HDs spin? Does screen do anything? Any noises?
תודה
Posted on Dec 23, 2008
Sd ms pro mmc sm xd dv 8000 slot is not recognizing card
Try a different sd card,, chances are your card needs to be replaced.. yes they go bad, sometimes very quickly.
Dec 30, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
Hp Pavilion DV 8000 (dv 8113 ea) heats up then hangs & turns off
I believe that would be the battery I would get a new battery that should solve the problem. When you use office or surf the internet that does not require as much power as playing games and watching videos. Just buy a new battery and that should solve the problem
Jul 18, 2010 | Compaq Presario CQ60-220US PC Laptop
Hp pavilion dv 8000 will not boot from DVD drive or Hardrive. It goes to LAN card regardless of precedent set in the BIOS
when u start ur system try pessing f8 or f10 or watever is the key for boot option nd from there u can select from which device to boot
Apr 05, 2010 | HP Pavilion dv8000 Notebook
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Blinking power light, but nothing happens.
It could be that your RAM needs to be reseated i.e. the RAM could have come loose and just needs to be taken out and put back in again. Hope this helps.
Oct 18, 2009 | Apple Power Mac G5 Desktop
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
I have hp pavilion dv 8000 and i get the error
system BIOS on hp motherboard allow hp approved hardware to be detected.if you want install net adapter that was not approved you have to remove BIOS whitelist & then flash the hp motherboard with modified BIOS.
May 16, 2009 | HP Pavilion dv8000t Notebook
HP Pavilion 8000 power light and battery light blinking
hi,
Hp recalls some king of batterys, maybe yours it is on this recall, contact hp web or phone to take advantege of this recall, otherwise appears that your battery do not work you may replace it.
Thanks
vcrtech
Apr 27, 2009 | HP Pavilion dv8000t Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Ei systems 4411 wont power on
The most likely cause of your ills is a failed motherboard Jake. Processors are pretty tough but unfortunately HP did a lousy job with the motherboards on the DV series and many, many of them fail and usually after the warranty is over.
Oct 30, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
305 people viewed this question
David Payne
David Payne
