Question about Motorola Mobility RAZR V3
What do clientshell.exe mean it always running on my phone
My phone alway have clientshell.exe running can someone tell me what the means please
    Brigadier General:
  • 7,752 Answers
That is a bluetooth virus you need to have the firmware reflash on the phone to correct this issue.
Posted on Dec 26, 2008
Error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
Phone is locked
remove battery and put back in
Apr 13, 2008 | AT&T Blackberry Curve 8300 Smartphone
I need to locate the cam sensor for dodge stratus 3.0 2004 model
Please tell us your NOT replacing a cam sensor because someone told you to get a code read at some auto parts store. This is like the flu spreading on this site. Codes DO NOT always mean a sensor is bad. Test it before you throw parts at it.
Feb 08, 2010 | 2004 Dodge Stratus
My N73 always switch off if i run it. not run about 2 second what is the problem
Check if the battery has swollen if it is then that is the cause of the problem,no matter how much you charge the phone it won't charge n if you try a lot it might blow up n i mean blow like a dynamite so change the battery or try using someone else's battery if it works.
if it still doesn't work then it could be a software problem.
Nov 18, 2009 | Nokia N73 Cellular Phone
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
C:WINDOWSsystem32keyboardservices.exe it always appear everytime when i open my computer. What does it means,how i can remove this
to remove it go to start and choose the run and type this (msconfig) and click startup and un check you problem
i hope i can solve your problem
Sep 03, 2009 | Computers & Internet
How to keep task manager in my pc
it means ur task manager is disable!!
then download redchat or do below activty
Click Start, Run and type Regedit.exe
Navigate to the following HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
In the right-pane, delete the value named DisableTaskMgr
Close Regedit.exe
and always scan ur sytem with latest defenation file
may be ur problem is solved.........
Jun 21, 2009 | Microsoft Windows XP Professional SP2
From what I understand, clientshell.exe supports Verizon Wireless' Active sync for push email services. Many people have experience your problem after updating their phone. As far as I know the only way to turn it off would be to do a backup restore to an earlier date to rid your phone of clientshell. Hope this helps.
Dec 16, 2008 | Motorola Mobility W375 Cellular Phone
I am trying to run tekken 5 on pcsx29.4 will it work.
I would have to assume since you didn't know how to setup a bios correctly that this is your very first emulator and this is the first time you've tried to use one. Go .::HERE::. and read Solution #2 . Read all of solution 2 please. Next read this page, all of it please, .::HERE::.
The reason why I sent you to those two pages is because one or all of the following things is true about your problem.
1.) You're using the wrong country BIOS for the version of the game you are playing (example you're trying to use a japan bios to play a USA game)
2.) You're using the wrong .EXE as your main emulator. (PCSX2.EXE is for Pentium 4 processors, PCSX2T.EXE is for AMD processors.)
3.) You didn't even bother to configure PCSX2 with video card settings and processor settings you left them all at default and tried to run PCSX2.(will 100% always result in a game crash lol.)
4.) Your computer does not even meet the bare minimum system requirements of PCSX2.
Every single thing here you could have avoided if you have read .::HERE::. always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always always
read the HOW TO or GUIDE of the person who made the program before you ask anyone any questions. Saves us both time. So please read that guide first (because I know you have not) then I'll be more then happy to help you further.
Jul 13, 2008 | Sony PlayStation 2 (PS2) Console
Phone is saying no memory left so cant retrieve messages aswell asnot being able to takephotos.
wondering the type of phone that you use.
anyway all phones and d most phone use what is called "shared memory"............this simply means that your messages,contacts,pictures,songs and virtually every information runs on your phone's memory.
to avoid "crushing" your phone just get raid of all those unwanted contacts,messages,pics and all that.
but then if any information would be of need please do a backup on your pc with the phones connection(usb,bluetooth,infrared) before delating them.
always remember to reserve space for your phone so that it can run safely.
good luck
May 16, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
