Question about Brother MFC-5840CN All-In-One InkJet Printer
Ricoh service tech. needing help with Brother MFC 5840cn
Customer has MFC5840 cn saying unable to init. .There is no paper what so ever jammed in the machine.Is this some thing I can reset in service mode or maybe some thing you have run into and know the prob..Any help would be greatly appr.Thanks thecopierteck@bellsouth.net
  • JMEA Dec 31, 2008
    I have the same problem. Tried everything I could think of. Cleaned all the inside, reloaded the driver several times. Nothing solved the problem. I can scan and fax but cannot print or photocopy. I noticed that if I put a piece of paper in the feeder, the message goes away as the paper closes a small switch that senses there is a piece of paper in the feeder (the feeder works fine and allows me to scan, but not using PaperPort, though). I am at a loss and would welcome some suggestions as to what to do, besides buying a new printer. John
    Champion:
  • 320 Answers
No tuwn the machine off and unplug then turn the machine on it will reboot
Posted on Jan 13, 2009
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
My brother printer is saying 'Unable to Init.'
This error message is sometimes due to foreign material under the printhead path or underneath where the printhead stops or parks.
Unplug the unit. Open the cover. Use a flashlight if necessary and carefully inspect the area underneath the printhead path. If the printhead is stopped or parked, gently move it enough to look at the area underneath. Common items are little bits of paper, staples, paperclips, push pins etc. Remove any foreign material.
Close cover. Plug in the machine.
Jan 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to init.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Dec 20, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to initialized
"Unable to Init" indicates a mechanical error, unless you're able to find a stuck paper or parts of a stuck paper or similar, you'll have to send the unit to service to have it fixed.
Jun 03, 2009 | Brother MFC-5840CN All-In-One InkJet...
My screen says unable to init. check manuel
Try cleaning the rollers located around the paper feed and making sure there is no obtructions in the way of the paper.
May 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
are u usin oem brother ink or generic? generic will not work
Jan 04, 2009 | Brother MFC-5840CN All-In-One InkJet...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
276 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
