Question about Zanussi TC7102W Electric Dryer
Tumble dryer not turning with heavy load
Does not spin round when lot of washing in thought it was belt although worn abit still ok asked in a shop told me it would be the brushes on the motor do u think thats the problrm please help
  • 979 Answers
It could be the problem. Check first to see if belt is tight enough and not slipping on drum. The spindle or axle the drum rotates on could be worn out. Try lubricating it if you can.
Posted on Jan 15, 2009
New Beko DRVS73W tumble dryer drum only moves in one direction and makes terrible noise
check the belt that goes around the drum to be correctly mounted at the motor area also inspect the rollers that hold and turn the drum
Aug 27, 2014 | Beko DRVS73W Vented Tumble Dryer - White
Why dryer won't tumble?
The belt could be worn and stretched.
Jul 20, 2014 | Maytag MDG2706A Gas Dryer
Drum will not spin on spin cycle Belt ok not slack water syphoning pump ok and working would it be the brushes in the motor compartment are worn
More than likely, it will be the brushes that need to be replaced,
you will need to remove the motor to do this.
Sep 23, 2010 | Bosch Washing Machines
Washing machine switched on, although timer runs it's cycle there is no action from the machine!
sounds like the motor or motor brushes worn,you 1st need to make sure its pumping ok. put it onto a spin make sure pumps ok,if no spin then check your motor...
Jun 19, 2010 | Indesit WA 125 Front Load Washer
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Zanussi TC7102W Electric Dryer Logo
226 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
