Question about Panasonic PV-V4660 VHS VCR
No sound My VCR not recording sound, after recording the picture result is very fine but without sound. Please let me know the exact point of fault.
    Novelist:
    Champion:
  • 275 Answers
And what about those cassetes whiche were recorded earlier? And In pre-recorded cassettes? Do you get sound in those? If yes, Then there is something wrong in your recording set up.
Posted on Mar 23, 2007
    Novelist:
    Champion:
  • 254 Answers
Check your hookup of audio connections both to and from VCR. does audio input of VCR go to the proper audio out of the TV & audio out of VCR go to the correct audio input jack of TV? Your exact hookup might not be like this, but this is where to start. Some VCRs may also have an audio source switch, so check for this also. If hookup is correct, and all cabling is OK, then an internal problem is possible, and repair of such is doubtful, as most VCRs these days are disposable; repair not recommended.
SOURCE:
My vcr plays commercially-recorded tapes fine, but tapes recorded on it or another VCR play with the sound distorted. The picture seems fine.
Sounds like its mechanism need some alignment. Guide pole alignment. Contact any service technician. This is technically skilled work. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Panasonic Televison & Video
Panasonic VCR/DVD combo - stopped recording sound
Seek tech support. This is not a self repairable work. Need technical skill.
Jun 02, 2012 | Panasonic DMR-E75V DVD Player/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
No video on playback after recording
There is a circuit within the VCR called an RF Converter. This is the circuit that converts the audio and video signals into the RF channel 3 or 4. It sounds like the vidoe is not being processed or the video is not being sent to the converter. Without tracing the video inside the VCR, I can't tell which is the problem here. You can try to play the tape in "review" mode (hit play then FF) and see if you get any video signal. If you do, then there is a possibility that the heads are clogged and need to be cleaned.
Please try that and update this with the results.
Thanks,
Dan
Mar 04, 2010 | Zenith VR4176 VCR
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 10, 2009 | Sony Televison & Video
Dvw-7200: no picture on the dvd
My dear friend I think you maybe by mistake put the function progresive scan on the dvd check on the remote control for that function and try to deactivate.Good luck
Aug 23, 2008 | Sanyo DVW-7200 DVD/VCR
No sound
have good picture from pre and recorded tapes, but no sound.
Nov 18, 2007 | Televison & Video
Visual
First, have you doublechecked the video hookup? It sounds like you are using the video/audio inputs to the TV, so make sure you have VCR video out cabled to TV video input, and the TV source/input selection set to that input (video 1 etc.). If this checks out, check for a dirty video head on the VCR, though a dirty head usually results in a blank or blue video display (older VCRs, snow). You could do a process of elimination by hooking VCR to a different TV and see what is displayed then. Lastly, I assume you've tried multiple tapes, just in case a home recorded tape was incorrectly recorded?
Aug 24, 2007 | Panasonic PV-7450 VCR
Unable to record or playback VCR tapes
All you can do by yourself unlesss you are a tech. Is run a head cleaner tape through it. It sound like a dirty head to me. Here is something a lot of people do not know, The video head and the audio head in a VCR are two separate heads. thats why you can loose picture and not sound. Best taken apart and cleaned manually with rubbing alchol but not advisable if you are not experienced due to high voltage and if cleaning improperly you can damage the unit worse. Good Luck
Nov 25, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Panasonic PV-V4660 VHS VCR Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
