Question about Konica Minolta magicolor 2300DL Laser Printer
Trying to change yellow toner, but toner replace is not highlated, therefore can't click on it.
  • jimaymn Jan 30, 2009
    same problem, tells me to replace yellow toner (although it is 48% full), wont allow printing, print menu option to replace toner is greyed out
  • lrohret Feb 03, 2009
    It tells me to replace yellow, I have tried putting in 2 new toner cartridges and it still tells me to replace the yellow and it won't print. I tried Menu - engine, Menu - replace toner, and Menu - toner. and this did not make it work.
  • 3 Answers
MENU (right arrow to Engine) MENU (right arrow to Replace Toner) MENU (right arrow to Yellow) MENU
Posted on Jan 12, 2009
No yellow color appeared while I doing photo-copy and printing
replace the yellow image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 26, 2015 | Office Equipment & Supplies
Drops toner inside machine. I just changed yellow high yield toner cartridge two weeks ago and it just went out. Changed cartridge and their was yellow toner inside machine. HELP
It sounds as if the toner has leaked, maybe it was cracked or seated incorrectly. Toner is so fine that if you use a standard vacuum cleaner the toner may just fly out of the back.
It's still worth trying to vacuum out the spilt toner. Remove all other cartridges first
Inspect the Yellow cartridge for damage to determine if it was that or the printer at fault.
May 18, 2011 | Computers & Internet
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
How do you change the magenta, yellow and black toners on the dell 3100cn
The toner carousel must rotate, so that you get the slot for the other toners in front of you.
Follow detailed instructions on the user manual, click here to get the manual :
Owner’s Manual
Nov 07, 2008 | Dell 3100cn Laser Printer
HP LaserJet 2820
Push the button to align another color and open the door and take notes on where the carousel should be when changing a toner, Not sure why it would bypass yellow altogether but may be resolved by manually changing out the yellow. When you open the door to the toner compartment there should be something on the door that depresses something in the machine which will unlock the carousel and allow you to turn it by hand when you depress the same lever with some type of tool that will fit in the slot. Rotate the carosel until the yellow is where it should be when replaceing it then let go of the locking mechanism and replace the yellow toner. hopefully between changing the toner out and powering the machine off/on will get you back in business... Hope this helps you out and if it does please list as a fixya... if not, you may need to upgrade the firmware and that's not to hard if your on the network already...
Sep 24, 2008 | HP LaserJet 2820 Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
Yellow toner empty
You will need to use the menu on the printer itself to change a setting Press "Menu Select" button to get the menu function Use the right arrow twice to select "Engine", then press the down arrow to the "Replace Toner" menu Press the right arrow for the "Toner Empty" menu Press the down arrow to get the Toner Empty settings Press the right arrow to change the Toner Empty setting to "Continue" Press the "Menu Select" button to confirm the setting. You should be able to print, you just won't have any yellow toner. When you get your toner cartridge, follow these instructions to reset the 'Toner Empty' setting to Stop so you will know when a toner is out.
Aug 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
183 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
