We are having problems with our projector. The screen (or light bulb) flickers. We have had it just a little over a year and first the colors got funky so we replaced the bulb. Now when we try to watch it(we use ours as a television), the screen flickers. Not quite sure what all to try. We have tried the resync button and that does not fix it. Any suggestions would be great!!
Comment by tcrody, posted on Jul 03, 2007
Thanks!!! Your a lifesaver!! You fixed our problem!!
We have an Epson PowerLite 54c that starts to flicker after it has been on for an hour. The screen will flicker with or without a computer image. Tried to synch but that did not solve anything. Is it the lamp or some other problem?
I turned on my Mitsubishi HC5000 projector one day and it was displaying green, inteads of the usual blue. I thought it would go away but when i watch movies on it, everything is green. What should I do?
Comment by Guest, posted on Jun 07, 2008
my projection is always searching and searching and nothing appears o the screen. by Steve Ameh
i had almost identical problems with an optoma h27, took the rear panel off, removed what dust i could get to and this seems to have cleared the problem
Rating Locked! (?) tcrody has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on optoma projector:
I have an optoma hd72 did the same thing. I pulled the bulb out and used a can of air/dust to clean it out, spraying it in all the vents as well. it fixed my problem also, and there wasn't much dust in it.
Was this solution helpful? Show your Appreciation by rating it:
we have a optima hd65 projector that has been fine . now it starts the same ,sound ,picture etc. but then after 30 seconds the bulb turns off. hundreds of hours left on bulb. no warning lights.after i shut it off fan comes on as usual.
Solution #4
posted on Jun 08, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
i hav bought sharp protector since 2 yrs n we use it for average 3 to 4 hrs in a day we hav already replaced the blub once as the person who sold it said that blub life is only 1800 hours n the blub has gone off again n the blub is costing Rs 18000 which very expensive iam regretting buying fr yr company as a friend of mine is using panasonic protecjor since 6yrs n use is for 8 hours a day n the bulb life is still on. please help me what am I suppose to do.
thankyou maya fr india.
Crazy, but its true!
I just bought a used Optima EP 758 an to my dismay a horizontal white lightning bolt flickered across my screen about every 15 second...after hours of setting it up! I found this blog and pulled the unit off the ceiling shaking my head in disbelief. After carefully unscrewing and pulling the case apart...sure enough, DUST! not a lot, but plenty on the fan wheel and on the inside of the case. I was too nervous to use my compressor (Especially at 90psi, enough to drive my framing gun) to blow it out, so I just used canned air and gently wipe EVERYTHING with a clean white (Easy to see what you picked up) undershirt (Thinner cotton). Put everything back together an WALLAH! FIXED!!!
...Crazy, just crazy!
Thank you for the fix blog
Solution #6
posted on Mar 20, 2008
Guest
yep, it also worked for me, on my Optoma EP716. OptomaUSA wanted me to ship it to them to get it fixed, (I'm in France).... and since it was not under warranty anymore, I decide to take it apart and clean it.(dust it off) Which totally solved the problem!
Thanks so much for the tip, it was very much appreciated!
Solution #7
posted on Jan 02, 2008
Guest
The Solution above works. My Acer PD525 would work great for about five minutes then start flickering, Changing to drap colors, and turn off. I replaced the bulb and still had the same problem. Thanks to this thread, I opened the box and dusted. It has been working great for 48 hrs and still kicking. Who would have thought dust would cause it to do that. Thanks so much. I was about to buy a new one because Acer Tech support is non existant unless you want to pay $2.50 a minute. Even if i had gotten a hold of them they would have had me send it in for repairs. This thread has saved me at least $1,000. Thanks again!!!
i have an ezpro610h and the no signal and optoma sign flashes.(and it didn't when i first bought it.it was on with out flashing)when i turned it on...i can plug my laptop on vga inputs and it works great.. but it will not pick up a S.video feed or a rca the yellow jack feed..i tried factory default settings...and sometimes it will pick them up after running for an hour but not lately..
