Question about IBM ThinkPad T43 Notebook
Changing dvd drives
I have a sr- 8175-m dvd drive and i need to install it, how do i get the old one out of my laptop in order to put the new one in..I used the little eject button but it won't pop out.
  • 21 Answers
Are you trying to remove the entire physical drive? If so there should be a small slide switch on the bottom of your machine to allow for easy acess. Try find that first, sliding it and gently pulling on DVD drive.
Posted on Jan 17, 2009
Insyde BIOS SCU 1.11 does not recognize a new DVD drive
You just need to replace your 80 pin data cable or power plug.
Good Luck
Aug 20, 2012 | Computers & Internet
I need to know how to remove a DVD drive for a HP lap top.
If your HP Pavilion DV6000 series laptop computer has a bad DVD drive, use the following steps to replace the drive
Purchase a new DVD drive to replace the old HP drive. You can use any slim DVD drive with a 50-pin ATAPI IDE Interface Connector. You will probably want a DVD burner since the original drive was capable of burning DVDs. The drive I used to replace the HP drive is a LG Black IDE Super-multi Slim Notebook DVD Rewriter - OEM version.
Unplug the power cord from your HP laptop. Remove the laptop battery from the back of the computer. This will eliminate the chance of power damage to your computer
Ground yourself by touching a metal object or touch your screwdriver on the ground while touching part of the metal. Unscrew the DVD drive screw circled in the Step 2 photo. Using a small Phillips head screwdriver turn the screw counter-clockwise until it is completely loosened. You may need to flip the computer over to get the screw to fall out. Put the screw in a safe location for later.
Put a small pointed tip object (a paper clip will also work) into the drive release hole on the face of the DVD drive. Use the hole to pull the drive out from the laptop body.
Remove the mounting bracket from the old DVD drive. There are two small Phillips head screws that need to be removed by turning them counterclockwise. Match the bracket up with the holes on the side opposite of the connection port. Using the two screws you just removed, secure the mounting bracket to the new DVD drive by tightening them in the clockwise direction.
Remove the original HP DVD drive face plate from the old drive. It can be removed by working it back and forth to loosen the faceplate. Once it is loose you should be able to pull the faceplate off.
Do the same for the new drive. Once the DVD faceplate is off, match the tabs of the original HP faceplate up and press in until it clicks into place
The new drive is now ready to install into the HP DV6000 series laptop. There is no need to hook up IDE cables and power cables. The new drive can simply be slid into the HP laptop.
Find the screw from Step 3. Make sure the DVD drive is pressed in all the way. Install the small Phillips head screw in the back of the laptop and tighten by turning clockwise.
Jun 19, 2010 | HP Pavilion dv6000z Notebook
How do I install aDVD combo in Toshiba 2410-S206?
Pretty simple operation.
On the bottom of the laptop, there is only one screw that holds the module in place. Remove the correct screw, and pull out the old cd/rom. Now you might have to remove any mounting hardware that is on the old cd, and install it on the new dvd combo. Slip it back in the slot, replace the screw, and you are ready to rock and roll.
Now that was easy, wasn't it?
Mar 17, 2009 | Toshiba Satellite 2410-S206...
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
How can i replace my cd to a dvd in my compaq lab top
You'll have to order a drive for your model of laptop (either from the manufacturer or from ebay), and have it installed. Most of the drives in this style of laptop are held in place by a single screw. Power down the laptop, remove the retaining screw, remove the old drive, install the new drive, and replace the screw. Windows will detect the new drive automatically, and then you can install the DVD software. Keep us posted and good luck.
Mar 07, 2009 | HP Compaq nx6110 PC Laptop
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
Installation instructions for dvd/cd combo for IBMLaptop.
If it is a direct replacement drive, exact size as old drive, then all you need to do is remove the old cd drive and slide the new drive into the slot until the back plug engages. Install new drivers as needed and any software that came with new drive. Hope this helps.
Jan 24, 2009 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Changed DVD drive in Compaq Presario X6000
Put a spare hard drive into the machine, installed XP onto it (the original OS for this laptop)...ran the HP bios update in XP and now it recognizes the DVD and is working OK.
May 14, 2008 | Compaq Presario X6000 Notebook
IBM ThinkPad T43 Notebook Logo
51 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
