Question about SanDisk Sansa m250 MP3 Player
I want to create a playlist on my SanDisk Sanso 250, but cannot figure out how. Can you help?
  • 758 Answers
Sansa MP3 players have 2 modes, MTP and MSC. In order for playlist to show up properly on your player it must be in MTP mode. First, go to settings then USB mode or just mode( depending on the player). then choose MTP. Once it's in this mode, connect to you PC. Open Windows Media Player and go to the library. Right click on the song of your choice then go down to "add to" then click on additional playlist. Type the name of your songs and click ok. Right Click on the next song, click on "add to" then click on the name of you playlist. Continue this until you playlist is complete. Click on the Sync tab at the top and then click on sync settings. make sure "sync device automatically" is checked off. scroll through the large white box and only check off the playlist you want on the player. Click ok and the playlist will start to sync to the player. Once complete, disconnect the player select music then scroll down to playlist and you will see the name of your playlist...
I hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on Dec 16, 2008
How do i create different playlists in my sandisk sansa clip. It will play all it will play albums. I have tried to drag a playlist from the lap top windows media player but it says it needs converting to...
1) Open the Sansa in 'My Computer'
2) Double click on the 'Playlist' folder
3) Drag the music you want from the computer into the 'Playlist2_bing.gif' folder
4) Highlight all the files (or the files you want)
5) Right click
6) On the menu that pops up click "Create Playlist" - on my computer it's the very first option, in bold
7) Playlist will be created in the 'Playlist' folder
8) Name it whatever you want and enjoy!!
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
Sanso Clip 2G from Windows Media Player
You may be syncing them to the wrong file. This is odd, but try fishing around the device for any "Music" folders. Then, you should be able to cop&paste the songs there. Please rate!
Jun 18, 2009 | SanDisk Sansa E280 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Sanso 250
i am not sure, but is it on lock?  when it is on lock and you turn the player on, it will say key locked system shutdown and then shut off. that might be the problem. hope it helps
Mar 21, 2008 | SanDisk Sansa e250 MP3 Player
To Go Playlists
you cant create double playlists
Feb 17, 2008 | SanDisk Sansa e260 MP3 Player
Can't add playlists
go to computer than click on Sansa e260
- Click on PPI NAND
- Click on PLAYLISTS
- Create a new FOLDER
- Give your playlist a name
- than put the music in it.
Nov 29, 2007 | SanDisk Sansa e260 MP3 Player
Can't create or play 'playlists'
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
Jan 20, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
91 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
