Question about GE WDSR2080D Top Load Washer
Motor wo'nt start
My GE Washer model WHDSR209DAWW just stopped. the thing is only 3yrs old.the lid switch is clicking, the motor turns in both directions
by hand the cap under the agitator is good, not stripped. the timer moves to the next phase as it should. the pump drains the water, but the motor just will not start. Please Help!
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
  • 942 Answers
SOURCE: no spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Posted on Jul 08, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
dcramer531
  • 1654 Answers
SOURCE: GE Washer WHDSR209DAWW Washer spins fine,
Sounds like the agitator may be locked up due to a bad bearing or possible transmission issues. Here is a link to a page that has several videos that can help you diagnose the isse and it is very helpful on all types of repairs. Wacth these and do some tests and see if you can find the issue, if not get back with me and we can go over what you tried and what you find out.
www.do-it-yourself-washing-machine-and-dryer-repair-help.com/GE-washer-is-not
There's a part under the agitator(which lifts off if you pull up from the bottom evenly on two sides) called the "Air Bell Coupler" that attaches to a metal toothed motor shaft with one bolt. More than likely the plastic teeth have stripped off from this coupler, preventing it from sitting tightly on the shaft, thus causing the agitator to not "agitate" properly. This may also be causing it to lock up and not turn if the little pieces get broke off and jammed.
Posted on Jun 27, 2011
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Magnetic Lid Switch or Other?
I would try the lid switch, part 388 on this diagram and parts list. You can check to see if this is the problem by taking the old one off and tape the two wires together and see if it will work. Using it without the lid switch creates a safety hazard. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=229918&diagram_id=21464425#d21464425
Jun 04, 2010 | GE WBSE3120B Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
No spin - agitate
You just do this
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE washer (WHDRR418GWW)(14 MO. OLD)HAS STOPPED AGITATING.WHERE TO LOOK? WHAT TO TRY?
My washer would fill/drain ok but would not agitate or spin. I unplugged the washer and listened for the motor to click. When the motor clicked I plugged the washer back in. Then I opened and closed the lid 10 times. I turned the washer to the drain/spin position and turned it on. The belt moved back and forth several times and then went into a fast spin.
Sep 26, 2008 | Washing Machines
WE HAVE A GE TOP LOAD WASHER, MOD.#WCSR2070T6WW. RECENTLY, IT WILL GO THRU ALL CIRCLES BUT WON'T SPIN. IT STARTS TO, BUT WITHIN 5 SECONDS, YOU HEAR A CLICK AND IT STOPS SPINNING. I PULLED THE FRONT PANEL....
  • it could be a problem with the water level switch; this switch keeps it from spinning until the water has drained.
  • or the motor itself could be bad.
  • the click you hear is probably the start switch on the side of the motor kicking off due to the motor pulling too many amps.
Jul 10, 2008 | GE Washing Machines
GE WDSR2080D Top Load Washer Logo
55 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
