Question about Compaq Presario R3202US Notebook
SOME OF MY PC FILE IS MISSING
MY COMPAQ CELERON PC IS NOT ALLOWING ME TO SIGN IN TO MY IM MESSENGERS....IT KEEP DISAPPEARING WHENEVER I WANTED TO SIGN IN.
Unmountable_boot_volume
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Dec 03, 2011 | Compaq Presario 5000 PC Desktop
I have a compaq presario 5000 pc running windows xp home sp3 when turning on the pc i get an error msg 514-cou or chassis fan not detected the fans all work i think the rpm's are not being detected i...
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time that did not have this error message or be able to work your way through it also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to PC health status press Enter you should see some of the temperature settings available you could disable the shutdown at the current the Temperature
hope this will help
Jul 27, 2011 | HP Compaq Presario 2500 HP Pavilion ZE...
I want to download audio driver for compaq pc notebook intel celeron 560@2.13Ghz please tell me the name of file to be downloaded
You need to go to the HP support site and enter your details, including the OS.
http://welcome.hp.com/country/us/en/support.html
Answer the questions, and HP will tell you which driver you need
Feb 02, 2011 | HP C792VU, Intel Celeron M 560 2.13 GHz,...
My dextop wallpaper disappearing and turned black whatever i select. my system information- Mycrosoft Windows XP Professional Version 2002 ...
If you're using a .jpg file for your wallpaper you need Active Desktop turned on in order to use the file for your wallpaper.
Opening sysinfo disables Active Desktop temporarily.
Thanks
Jan 31, 2011 | Intel Computers & Internet
My Compaq win32 is too slow and whenever i download it will corrupt the file?
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. download registry cleaner reg in out to clean registry and to fix the error
Sep 16, 2010 | Microsoft Windows Vista Home Premium...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Need mainboard driver
Proceed to the following link, however you will need to sign up with a user name and password to download the file
http://www.bioticaindia.com/p4m266a-8235.html
Dec 07, 2008 | Intel Motherboard
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 12, 2008 | Compaq Presario 1700 Notebook
Compaq Presario R3202US Notebook Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
