Question about NEC VT676 Multimedia Projector
Lamp error on nec projector - NEC VT676 Multimedia Projector
  • Pualpsps May 24, 2009
    I have a NEC 170 With a Blinking red status light that indicates "lamp error" with six flashes and a pause. It happend a few weeks back and I removed the bulb to seek out a repalcement and when I put it back in it just started working again. Any Ideas?
  • 82 Answers
Have you changed the lamp? is so check out fixmyprojector.com
the ballast most likely needs to be replaced
Posted on Jul 26, 2009
  • 37 Answers
Six blinking red lights usually means a "lamp error". You should wait one minute and try again. It does not mean that the lamp has to be replaced.
Posted on Aug 11, 2010
4 Suggested Answers
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
dhiman
  • 115 Answers
SOURCE: NEC VT676 lamp error
indicating ballast unit problem
Posted on Sep 27, 2008
projdoc
  • 2237 Answers
SOURCE: blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Posted on Nov 17, 2009
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
NEC GT6000 LCD PROJECTOR
check the lens cover hood to see that it's on correctly, and that the lamp door is closed. if they are, check the switches. on the hood and the lamp door, there are plastic protrusions that hit the switch activators. if they are broken off or warped, you need to replace the door/hood. if they are there, check the switch itself. replace as necessary.
Nov 17, 2009 | NEC GT6000 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Sep 01, 2009 | NEC VT695 LCD Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Sep 11, 2008 | NEC VT676 Multimedia Projector
NEC VT676 Multimedia Projector Logo
989 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
