Question about GE DWXR483EBCC Electric Dryer
My ge dryer wont start
Ge dryer model number dllllr23eg1ww
it wont start at all. the start control knob looks very worn out even though the dryer is less than 2 years old. i turned the switch with plyers though and it still wont start, what else could be wrong?
  • 547 Answers
There are 2 fuses located one on the heater side at the top and the other at the exaust side at the bottom if you hard wire the one then the other you can figar out witch one it is if none work hard wire both then replace them.
Posted on Oct 17, 2013
  • 943 Answers
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Posted on Dec 16, 2008
Control panel turns on but dryer won't start. Start/pause button just beeps when pushed. Opened the front panel to the door switch with multimeter. It looks fine.What could be the issue?
your gonna have to go deeper than the door switch,do you know you can't get the blower motor for this dryer anymore,i don't know why they had to have two motors in their dryers?could be a broken belt,computer issues,bad t-stat or thermal fuse,the only way to tell is by checking it out with meter,also make sure you have 240 volts coming to the dryer,go in the back where the cord connects to dryer and check it there,there's no one answer for this problem,you just have to take it apart and start reading out the thermal fuse high limit t-stat,stuff like that,to find out.i remember the first time i worked on this style dryer,it took me around 20 minutes to figure out how to get it apart,some jerk put the control panel screw behind the knob,had to pull the knob off and then remove the screw to get the top off to take it apart lol,and they have a funky belt setup and two motors,i gotta tell you i would never buy a ge dryer,to much just to dry clothes.sorry i can't help you out with an answer,you can go here,put your model number in and see the parts in your dryer
https://www.searspartsdirect.com/model-number/dpvh880ej0mg/0432/0151200.html
like i said,i only worked on one of these style dryers and it is different from regular dryers,if you can't get it open check the control knob,pop it off and as far as i can remember,this was like 8 years ago i removed the screw behind it,then you can get at the screws to remove the top panel to get into it.wish i knew that at the time,thought it was just gonna be a regular ge dryer repair
Feb 19, 2018 | GE Dryers
I have a GE profile dryer model# DPVH890Ejww upon starting it turns for about 2 seconds then stops turning.I was going to check the belt ,But couldn't even figure how to get the back off and I'm very...
couldn't pull up the model number so if it's a newer model you have to take out the top panel screws in the back,then go to the front and pop off the timer knob and there's a screw there that lets you remove the front control panel and then you can get at the other screws that hold the top on,this isn't an easy dryer to work on,it has a funky belt system in it.if it's an older model open the door and look up at the top panel,you'll see two screws there,remove them and remove the top panel,then look down the sides and you'll see a screw on each side remove them and remove the front panel.hope this helps.i'm going by memory and unplug the dryer before you get into it.
Oct 21, 2013 | GE Dryers
Looking for a Model Number for my dryer
Post a picture of it with the door open
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2012 | Dryers
Searching for Model Number for a
post a picture of the dryer with the door open
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
May 21, 2009 | GE Dryers
The knob stem that for the turn on knob broke
Hello keppoet,
Since you only provided a brand and not a model number, I cannot track down the exact control knob that you require but here is a link to a website that you can use to get that part yourself. If this fails to provide the right info, please include the model number with the GE Brand next time..
Hope this helps you.. Here is the link http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Regards,
Rick
Nov 24, 2008 | Dryers
Installation of part no. WE4M190 (timer) in GE gas dryer DPSQ475GT5ww
take off the back panel look closely at the timer you will see a tab that you carefully pull up a little and twist the timer off. to take off the knob in the timer opposite the knob there is a pin that you pull out and the knob will pop off.
Jun 10, 2008 | GE DBXR463GB Gas Dryer
Start knob broken off
G/E customer service can help you the number is 1-800-626-2001 or even a local appliance store can order it
Dec 06, 2007 | Dryers
GE DWXR483EBCC Electric Dryer Logo
396 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
