Question about GE GBS22HCP Bottom Freezer Refrigerator
Fridge not working, freezer is
Fan on the bottom is running fine, when I move the big black bowling ball looking thing it makes a noise and seems like it is running. fridge is just not getting cold, but the freezer on the bottom is.
  • kenneth_mart Dec 17, 2008
    just got finished melting the ice off the back of the freezer. was told by a local tech this will only cure the prob. for about a week. will need to get a service tech to check the thermostat or coupling. any way fridge seems to be blowing cold air but the fridge settings are not alphabets, they are numbers. don't know about a little door just seen ports on top and bottom of coils where ice was.
    how much you think it would cost me?
    Novelist:
  • 161 Answers
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
If you want mor info to DIY check out: ronbuice.com
Posted on Dec 16, 2008
  • Ron Buice
    Ron Buice Dec 17, 2008
    Defrost system failure. Back before we had auto defrost the fridg had to be manually defrosted just like you just did. Some don't have a door, just a direct vent from the freezer to the ref, anyway the ice build up is the problem.
    Defrost system:
    1. Heater, timer, and thermo disc.
    one or all could be bad and they have to be checked with an OHM meter.
  • Ron Buice
    Not sure what the prices are in your area but it is sure worth fix'n.
    With your model number you should be able to get prices on the parts.
    Defrost timer - $25-35
    Defrost heater - $30-40
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
It sounds like a bowling ball rolling around inside the fridge.
Sounds like maybe one of the mounts for the compressor might be bad. The compressor is around the size of a bowling ball and does need the vibration dampened to stop noises like that.
Jul 03, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
Jun 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
Dec 30, 2006 | Zanussi ZX56 / 4 Bottom Freezer...
GE GBS22HCP Bottom Freezer Refrigerator Logo
403 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
J Rosado
