Question about Tomtom ONE GPS Receiver
Photos of tomtom one power on fix
please could you send me the photos of your tomtom one fix ?.
I have the same problem,with tomtom not switching on.
My email address is stuartclee@tiscali.co.uk
Thank you
  • 5 more comments
  • morc53 Mar 16, 2009
    with a tomtom one the diodo zener is burn but i want to know the number for the diodo zener and the volts
  • morc53 Mar 25, 2009
    can you send pictures for a tomtom one 3rd edition for located the chip for the power supply thanks
  • john466 Apr 23, 2009
    I have had the 'Green Light of Death' creep up on me. At first it was related to external power and I could get my TomTom One 4N00.001 to start on internal power if I waited 10 minutes or so. But now its just dead. I've been inside, its different from the pictures, and found that a very large current flows (>120mA)between the 'on' switch contacts when I put a meter across them. Looks like bad news... At the current cost of new devices and the high cost of repairs I'm thinking of trying something along your lines. Do you know if the bits are the same? I'd greatly appreciate your comments.
  • spiderman58 May 11, 2010
    I have desold the LTC3455EUF to replace it, but now i don't know the sense with i have to sold the new chip!? Someone have a hight resolution image of this zone of the pcb?? Thank you all in advance. Bye. Doriano. My email: breath@tiscali.it
  • cool max Jan 19, 2012
    after replacing the the zenner and LTC3455 the unit still has GLOD.i know both the components have been changed properly and are working(tested) the is another fault which i can't work out.the power on/off switch is grounding..any help on this?
  • Bill
    Bill Oct 25, 2013
    cold you send me pics on how to fix my Tomtom ? Thanx, Bajawfo@yahoo.com
  • 5 Answers
Attached is a sequence of photos on how to get to and change the power control chip - the one that is probably damaged. This is for the Tom Tom I repaired and yours could be different however, there will be a power control chip of some kind (check out the part numbers to see which one it is) and it will be this that is damaged and will need replacing. The Power control chip is the hardest to replace as you cannot get to the 'legs' to solder them. To remove the old one, just apply a large soldering iron bit (with a blob of solder on it to make good thermal contact to the top of the chip) and heat up the whole chip until it is free. Lift it off straight away with tweezers. Clean up the solder pads with solder wick and then apply a SMALL amount of solder paste to each pad. It is improtant that this is a SMALL amount and is equal on all pads so the new chip sits square and true when you put it on. Make sure the chip is in the middle of the pad patern and push it into place. Now for the tricky part....either usa a large soldering iron and heat the chip until it melts the solder paste and drops into place or, use a hot air gun with a small nozzle and do the same thing. Great care needs to be taken to ensure you do not heat up the near by parts so the soldering iron is best but you have to remove it as soon as the chip falls into place. The surface tension of the solder should centre the chip up if it is slightly out but you need to get it possitioned as good as you can before you heat it up. Take care not to move the chip as you heat it. You will need a fine bit in the soldering iron for the diode and any other parts you may need.
You should start with TT1 and work through to TT7.
As well as this chip, if the power supply went high (12 volts) then the zener diode on the input to this chip will also have been destroyed - you should see signs of this just by looking at the device (see photo TT6)
The most difficult bits are: -
Opening the connector to the LCD. This can be done by gently lifting up the PCB to see the connector on the back and then pushing up the 2 ends of the connectors white locking bar. Replacement is also very tricky but with care it can be done. As an alternative, you can remove the LCD complete by gently flexing the plastic surround to it and freeing the display from the case. It is then easy to disconnect and re-connect the LCD to the PCB.
Removing the tin cover from the back of the PCB so that you can get to the power control chip. This takes time and a hot soldering iron with good solder wick to remove the solder. Having liberated a couple of lugs you can remove the others by gently lifting the cover near to a lug and heating that lug to pull it through the PCB. Don't burn your fingers though!
The parts are easy to obtain from either Farnell or RS Components - RS have trade counters you can go to and Farnell have a retail side CPC you can find them at http://cpc.farnell.com/. If you have problems let me know and I will see what I can do.
photos of tomtom one power on fix - 1f3ac3f.jpg2967b19.jpgphotos of tomtom one power on fix - 7d94e2e.jpg1ea2d29.jpg7d94e2e.jpgfece292.jpg
Posted on Dec 17, 2008
  • Aaron Horn
    Aaron Horn Dec 20, 2014
    This is really old now but do you have any higher quality pictures of the PCB around the USB connector for this model? I have accidentally removed a few of the smd resistors and need to put them back in place!
Fantastic guide, thanks so much.
Just to add - Farnell order codes:
5.6V diode
Manufacturer:
ROHM
Order Code:
1679979
Manufacturer Part No:
EDZTE615.6B
Power Chip:
Manufacturer:
LINEAR TECHNOLOGY
Order Code:
1273944
LTC3455EUF#PBF
Posted on Aug 09, 2010
My Juki DDL 5550-6 machine is not turning on. How do I fix this?
HI Gina
did you please check power source coming to power switch or No ? one more thing , please let me know which control box model you are using then i can send to you photo for fuses place to check maybe one fuse burned and need to replace.
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Feb 09, 2015 | Juki DDL-5550 Industrial Straight Stitch...
When TomTom is switched on a white cross on a red background flashes all the time This is after being on tomtom home.
Try to update your tomtom software. would this white cross mean that you have reached your destination? Can you post me the model of your tomtom that would be very helpful
Sep 30, 2008 | Tomtom GPS
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
TomTomGo 910 - Green Screen
Mike sounds like an IC glich which is send it back kinda problem if you send it back and they can't fix it they usely send you a NEW one
Jul 15, 2009 | Tomtom GO 910 GPS Receiver
Broken Screen
There's really nothing we can do for you about that. A broken screen is not something you can fix yourself. Go to tomtom.com and contact support, and they will walk you through sending your tomtom back to them for a repair or replacement.
Please rate, thanks!
Feb 23, 2009 | Tomtom ONE GPS Receiver
No gps device
Sometimes it can take a TomTom many minutes to obtain satellites. To give it a chance and to test it make sure you have a clear 180 degree view to the south ( that's if you are in the northern hemisphere ) . Its to the north if you are in the southern hemisphere.
So, put the TomTom with it's back facing the equator ( all the GPS satellites are above the equator in an arc ) it's almost straight up in fact but towards the equator.
If you switch on , let it boot up , then tap the screen near the bottom right where you see a bar graph . ( see photo's and finger indicates where to tap position )
The screen will change to another screen and again you should have the bar graph on right hand side with a battery symbol either below or above. once again tap the bar graph and a larger STATUS screen should appear. You should be able to see the TomTom scanning for satellites . Any it receives will be GREY but grey ones are not yet locked on. If any of the bars on the TomTom get a fix or lock on they will turn BLUE . Only when the TomTom has 3 or more BLUE satellites can it present a fix on your location. If none of the bars on the graph ever turn BLUE then you have a faulty TomTom or possibly corrupted data on the SD card. If you get ANY of the bars turn BLUE then it's likely your TomTom is working OK but is just having difficulty locking onto any satellites. You might have to wait a while or move location.
Once the TomTom gets a fix , even if you turn it off then on again it will remember what satellites it was locked onto before so it should not need to scan again and should find the satellites real quick or at least quicker. See photographs below for the 3 stages to go through to check status.
( NOTE : The photograph shows a TomTom ONE v2 but almost all models of TomTom show similar screens ) See last photo where one of the bars is GREY , this shows it's receiving that satellite but it's not strong enough to get a fix from it. The last bar shows the TomTom knows there is a satellite there but currently has no signal from it. The BLUE bars show good reception and fixes on those satellites.
I do hope this helps solve your problem but if not then please revisit this forum and post any questions again and i'll see if I can help.
Please remember to rate my comments and recommendations if you have found them useful at all by clicking on the coloured diamonds on this page.
Aug 10, 2008 | Tomtom GO 300 GPS Receiver
Tom Tom shows green light but won't power on
HAVE YOU TRIED THE RESET BUTTON? IF SO PRESS THE RESET BUTTON THIS SHOULD RESET THE ERROR WITH IT
Jan 23, 2008 | Tomtom GO 910
Faulty tomtom go 910
have to send it in to get battery replaced.
Jan 20, 2008 | Tomtom GO 910 GPS Receiver
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Apr 27, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
5,825 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
