Question about Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
How does one change the paper settings so that when making copies, the copies come out "portrait" and not "landscape"? We can't figure it out. Need to know where / how to change page settings on the Canon imageRunner 5055 copier/scanner. Thanks,
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    From what you are asking I'm guessing that you are tring to print to the copier from a computer? If so, you have to go to your printer properties and manually choose "Landscape" instead of "portrait". Also, you have to make sure you have that size paper loaded in your copier. The third paper tray can be set to any paper size. Good Luck
    Scholar:
  • 117 Answers
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Posted on May 06, 2009
  • Josh Lloyd May 12, 2009
    You may want to check if your paper is loaded in LTR or LTR-R. If you are using 8.5x11 letter size (LTR) try rotating the page and changing it's mode.
    Are you copying LTR? Do you have a document feeder? How are you inserting your page into your feeder or aligning the page on the glass? (Where are you positioning the long and short edges of your page?
My copier at work is copying my work In the landscape mode, I need it in the Portrait mode. Help me , phone # 718-617-5586
are you sure that drawer did you choice ? I mean, you must select paper drawer.
first drawer is A4 (portrait)
second drawer F4/Folio/U2 (landscape)
third drawer....
see on the display...
May 03, 2011 | Canon imageRUNNER C3200 Copier
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
My copier is making landscaped copies from the top feed. How do I set it back to portrait?
Under user mode ( asterix key ) under copy sett. set. the auto orientation to off.
May 24, 2010 | Canon ImageRunner 3025 Black and White...
When it copies, the copy comes out landscape and i can not change the paper select option to show portrait. also, it cuts off the bottom of the page as well
Kindly change the direction of the original. If at present you are keeping it horizontal way change it to vertical. You will get the correct print.
May 19, 2010 | Canon imageRUNNER 4570 Copier
Cannon 2200 always copies in landscape mode
Hello sir;At least you have to set up one paper tray to portrait direction, then when you make copy, use auto select tray. check user guide how to program it.
Jun 03, 2009 | Canon imageRUNNER 2200
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
My office has a CANON IMAGERUNNER 3570 and all of a sudden all of our incoming faxes are printing off landscape instead of portrait style and our faxes are being cut off and we cant read the bottom. Please...
In the cassette change the blue dial back to the correct type, either a4 or A4R (landscape). Sounds like you have to set it back to A4, Blue dial right hand side, front of cassette when you open it.
Or press the paper select button on the copy screen and see what it has been changed to, then change the dial in the cassette.
Jun 09, 2008 | Canon Office Equipment & Supplies
Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Oct 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
Canon imageRUNNER 5000 Copier Logo
1,200 people viewed this question
old marine
old marine
