Question about Samsung SCH-u740 Cellular Phone
Alias U740 ESN question.
Hello
Have a Samsung Alias u740 cellphone that was diagnosed with a broken charger port (for charging) by Verizon. Doesn't charge via AC or car adapter. Phone works great otherwise. The port is connected to a motherboard. If I replace the mother board with one I purchase online will it still have the same ESN # or will it have one from the parts phone purchased online?
Thanks!
The screen on my samsung double flip phone has gone white, what do I do to fix it?
I guess that is a Verizon Cellphone. It is most likely that the LCD has lost grip or contact from the main board or has gone bad . 1. You may disassemble it and check the LCD contact points on both the board and the screen...detatch attach it firmly or
2.You may have to replace the LCD completely.See what the LCD looks like here ....
http://cgi.ebay.com/OEM-SAMSUNG-ALIAS-SCH-U740-COMPLETE-REPLACEMENT-LCD-/370461654715?pt=PDA_Accessories&hash=item56413c3ebb#ht_500wt_689
I hope this helps you.
Good luck !
Mar 11, 2011 | Samsung SCH-u740 Cellular Phone
Bootblock version u740:2L05.2 on Samsung Alias cell phone
I dont have a solution to this problem but I have a similiar problem. I have an Alias version 2 and it gets stuck in USB download Mode, bootblock version u750:CD13.1. All I want to do is retrieve my address book which for some unknown reason is also not backed up online. Any thoughts?
May 09, 2010 | Verizon Communications Samsung Alias Cell...
My cellphone will no longer charge off of a wall charger
Hi there,,, are you with verzion? you can try a PRL update to get the new firmware,,, see if this fixes anything! To update your PRL, dial *228 and chose option 2
Jan 20, 2010 | Samsung SCH-u740 Cellular Phone
Alias sch u740 bad reception
hey, make sure that the simcard that you are using is supported by your celphone, the one that they called openline means all networks or simcards can be use with it.
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Aug 05, 2009 | Verizon Communications Samsung Alias Cell...
Where do i put in my simcard on the samsung alias?
hi thanks for using fixya!
Unfortunately, you cannot. Verizon phones have integrated SIM cards that you cannot take out. You cant unlock a verizon phone.
Regards!
May 31, 2009 | Verizon Communications Samsung Alias Cell...
Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
May 30, 2009 | Samsung SCH-u740 Cellular Phone
USB cable won't charge
Could be a borker charger port. Thats what I have.
Dec 07, 2008 | Samsung SCH-u740 Cellular Phone
Samsung u740 cellphone
it would not cost much like about $40.00usd to replaced....so start calling around to mobile service centers close to you for a cost.
Aug 18, 2008 | Samsung SCH-u740 Cellular Phone
Samsung u740 phone and itunes
Unfortunatly store reps have mostly only one thing in mind and that is to sell, sell, sell. Itunes uses a protect format called aac. which is unable to be played unless it is converted, the samsung alias (aka u740) does play MP3 format. My suggestion to you would be to use a program called Daniusoft Media Converter, to convert the music you have to mp3 and then transfer them to your phone via memory card or Verizons Music Essentials kit.
Nov 22, 2007 | Panasonic KX-TG5561VZCT VERIZON/CENTURYTEL...
Samsung SCH-u740 Cellular Phone Logo
187 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
