Question about Kenmore 3.2 cu. ft. Top Load Washer
Vibration Washing Machine Violent Vibration I am in Cozumel Mexico. My name is Earl Born. I can only be reached via email: ebspektek@hotmail.com My washing machine was marketed as a KENMORE Model 110.81821100 with a serial number C91455168, but I recognize it as a Whirlpool product. My washer has worked perfectly for 15 years but all of a sudden it has developed a violent viberation at high speed spin. It has been in the same location, on a cement floor and I have double checked the leveling. I have tried manually distributing the load but it doesn't help. As the basket starts spinning, I can see any unbalance gradually reduce, but as it comes up to top speed it starts going off center by more than half an inch and starts really banging hard. The off center action is not happening on every reveloution, I would guess that it is about once out of every 6 or 8 revolutions. I have removed the cabinet and inspected, but cannot see anything unusual. With the basket laying on it's side, the balance ring #387868 appears to be 1/2 full of liquid. Is this normal? I use well water, which is fairly hard. The outside of the basket has some residue, but the inside is perfectly clean. We had two huricanes last year which caused some additional water contamination, but I have always used filter screens at BOTH ends of the supply hoses, and clean them about once evert two years. I sent this message to Whirlpool, but their reply indicated that I would have to work directly with Sears and supplied an 800 number for Sears, which will not work from here in Cozumel, Mexico, and a link where you can order home service but not in Cozumel. Your help will be greatly appreciated as I don't even know the principal of the Unified Balance System. If I remove the impeller and release the basket with the spanner nut to remove the basket for inspecttion and cleaning, will I violate the tub seal? Is there an easy and safe way to keep the brake released so I could watch the balance while it spins down?
  • 2 more comments
  • Tony Visco Nov 26, 2007
    There is a excessive vibation during the spin cycles. I have checked and all the springs are OK. What else may be the problem? Model #11020922990
  • Laetitia2604 Mar 17, 2008
    I have the same problem of excessive spining during rising. the machine moves on the floor because it spins so much. Except my machine is brand new. it did it on the first cycle I tried.
    But when I look inside, the basket (drum) does not seem to be balanced. it's leaning more on one side. is it normal ? how can I fixed that ?
    I bought it at Sears but struggled with them for the delivery for 3 weeks so I don't want to deal with them again so I would appreciate any advice on what part can go wrong (my machine is a Kenmore top load 500 series)
    thanks
  • Anonymous May 12, 2008
    washer go"s out of balance very easly:if i stop it and reajust the load it will be better. sometimes. kenmore toploader.
  • rev_jonz Aug 09, 2008
    I have had this washer, kenmore HD 110 80 series 92284800 for many years. It recently started banging as if the basket has an off center load. It does this every time it spins now. Any solutions?
  • 67 Answers
A few things affect the vibration on that machine first leveling u can level it by pulling the control console towards you and its reset the back feet, second there is a common spring that breaks in the back hooked from the back of the tub to the back panel of the machine base check for that, then there are also suspension pads under the suspension plate small brown plastic pieces three of them right left and rear if one or more is missing there will be a baad vibration hope it helps worste case scenario you might need a new machine base at that point i would buy a new one
Posted on Mar 23, 2007
  • 41 Answers
'skate plate' needs inspection
Posted on Apr 10, 2013
Suspension plate need help
Posted on Sep 23, 2008
Violent vibration of washer machine
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Mar 02, 2011 | GE WJSR4160DWW Top Load Washer
I want to know my password my email is sultanfazal@hotmail.com
essaye ca http://www.softrads.com/modules/wfdownloads/singlefile.php?cid=1&lid=16 or else this:
If you think someone has changed your evil caring passwords or you do not remember your answer to the secret question, write to passport_fr@css.one.microsoft.com and follow this procedure:
Here is the standard procedure for submitting your application:
You explain your problem in detail and then:
If you think an unauthorized person has accessed your account and changed your password, secret question and your response or information from your profile, please provide the requested information.
* Name
* Username (Account problematic)
* Date of birth (day / month / year)
* Country / region
* State / Dept / Prov.
* Postal Code
* Approximate date of your last login
* Approximate date of account opening
* List of all old passwords you used with this account and that! remember
* List all of your files that you remember
* Name of your ISP. If you access your account from a non-personal computer (for example, from a school or workplace), indicate the name of the corresponding organization.
Once this information reaches us, we can reset your password and send it via email to the address from which you sent us your request.
Hotmail can easily know who logs into this account and now back up its warning to ISPs where the latter, closing the access ...
"If you have not already, you should add another email address (if you have one) to your Hotmail profile. So you can use the reset password email to reset your Hotmail password.
To add or edit your e-mail alternative
* Go to Passport Member Services: memberservices.passport.net
Dec 22, 2010 | LogOnce Password Assistant
I am just trying some very simple written instructions on how to set up e-mail addresses on my home computer? I was born in 27 and my computer skills are not the greatest.
If you travel from time to time and would like to check your Email anywhere you go, on any computer connected to the internet, I would suggest going to a free internet Email service like hotmail and open an account. All you will need to do is come up with a user name and a password for you to log into this account. It's simple, really... I use it in preference to my home internet provider as an Email service.
Here is a link to hotmail's website:
www.hotmail.com
I hope this helps... Good luck.
P.S. If you have any questions, feel free to ask. :o)
Oct 09, 2009 | Microsoft Outlook Express
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Hotpoint washing machine vibrate/oscillates violently when on spin mode. Installation instructions tell you to adjust the feet, which I have done. I have also tried different sizes of load - no difference...
have you removed the transit bolts? this is the usual cause of violent vibration. if not, do not use the machine till this is done as you can cause a lot of damage
Sep 03, 2008 | Washing Machines
Humidity Issues
Canon has recalls from time to time for things like this. The best way to find out is to get a hold of their tech support at:
http://www.usa.canon.com/home
Jun 30, 2008 | Canon PowerShot SX100 IS Digital Camera
Where do i pour da napisan inwash liquid
Hiya Shofina... best to follow Manufacturers guide... see this site..
http://www.vanishstains.com.au/napisan_solutions.shtml
Regards Faggly
Mar 18, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Open Questions:
See all Kenmore 3.2 cu. ft. Top Load Washer Questions
Kenmore 3.2 cu. ft. Top Load Washer Logo
231 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
