Question about Microsoft Xbox 360 Console
Ring of fire
How do u fix the ring of fire three red lights around the power button
    Scholar:
  • 31 Answers
When someone say that his/her Xbox is having red ring problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Posted on Feb 20, 2009
How can I fix "Red ring of death" on my XBox 360
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death" or "Red Lights of Death" or "Red Ring of Doom"), instead of the one to four green lights indicating normal operation, represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the hardware failure occurs, or not at all. If the console freezes occasionally, the error will not necessarily follow. The technical problems seem to affect some generations of consoles more than others. e.g. Xbox 360 60GB This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console. The 3 flashing lights can also be caused by power surges; if the console is connected to an outlet that receives a power surge, it may have a failure and the 3 lights will appear as long as the console is plugged into the outlet. Turning off the console, unplugging all power cables and plugging them back in, and restarting the console will fix the issue in this case. hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
An incomplete red ring circle appeared
My xbox has a red light on the power button, and nothing apears on the tv.
If you are getting three red lights around the power button then you have got the infamous
Red ring of death problem (commonly known as RROD) it occurs when there is hardware failure
due to overheating.Contact Microsoft customer support and they should either replace your
device with a new one or fix it for free if you are still under warranty period.But if are off warranty
then Microsoft charges something like $140 plus the cost of shipping since you will have to send
it to them to get it repaired.Other option to get a local technician fix it for you in your city.
Oct 27, 2010 | Microsoft Xbox 360 Console
A red ring around the power button comes on xbox 360
It's called the RROD or the Red Ring Of Death. Typically, it's from your 360 over-heating. You have a couple of options open to you: 1) Send it in to Microsoft and have them fix it; which will take a month or 2 for them to do, 2) pay someone who knows what they are doing to fix it for you, 3) go to ebay, by the parts to fix it and then attempt to fix it. If you are not sure about what you're doing or how to go about doing it, then I suggest you don't try it. There are several YOU TUBE videos on how to fix it. Alot of them are just ****. Some are legitimate ways to fix this problem. Firstly, do not actually bake your mainboard in the oven. That's absolutely insane. Also, do not try the "towel trick". It's a good way to permanently ruin your board and is dangerous because you could cause a fire to start. Please leave feedback and a rating on this information.
Jun 15, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
Green light doesn,t come on on front stays red
first solution was right in most respects but it matter how many of the lighta on the power button are on 1 or 2 lights may be fixable by making sure all of your components are firmly attached if there are three or four lights it is a critical hardware failure most likely caused by over heating . if you are still under warranty (red ring of death warranty is 3 years) then you can send it to microsoft and they will fix it . if you are not under warranty they will charge around $180
Jul 08, 2009 | Microsoft Xbox 360 Console
When i turn on the xbox360 three red lights come on around the on button
if its three lights with the right upper quadrant not lit then you have the RROD..red ring of death..call microsoft and get the console replaced..i had three consoles replaced..before calling them do check if the cables are properly connected..questions which customer care asked me where: what is the light status on the power brick?green...is the power cord directly connected to the mains?yes..have you modified the system?no
i got mine within 4 days.eeb0cb0.jpg this is the image of the infamous RROD!hope it helps..
Oct 29, 2008 | Computers & Internet
MY XBOX 360 HAVE AN RED RING AROUND THE GREEN CENTER POWER BUTTON
thats bad means a fault if u get three it means the ring of death xbox is gone no good ill ask my brother what one means and how to fix it he is really good with those gaming things
Sep 10, 2008 | Video Game Consoles & Games
Won't load game keeps blinkng red light
If the XBOX 360 is blinking the color RED in three of the four quarter of the ring around the power button, you will have to contact Microsoft for a replacement. This is what is known as "Red Ring of Death." You can find plenty of information on it if you Google it.
Click HERE for a video of the Red Ring of Death.
Click HERE for Microsoft's support system for the XBOX 360 and get in touch with Microsoft to get your replacement started.
It's the ONLY way.
Good luck.
Cyryl
Dec 10, 2007 | Microsoft Xbox 360 Console
3 flashing red light on console
uh well u got the three red lights of death it sounds like... and i also had those. while im no expert on this stuff, iv seen that u can put ur 360 sideways on a table, wrap it in towels(and i mean like 2 towels, wrap it up completely) and turn it on and leave it on for about 10-15 mins. just make sure a fire doesnt start in those 10-15 mins(believe me you dont want to call the fire company and tell them u started a fire wrapping ur game console in towels), ok then after u done waitin turn it off, unwrap it, and let it sit until it is cool, and try turning it on. it might work, its supposed to work because those three red lights mean that theres a malfunction in the 360 itself, such as wires or sumthin, and extreme heat may melt the wires and fix the problem, how i dont know but theres so many stories of ppl who have pulled it off
Sep 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
