Question about GE GSS25JF Side by Side Refrigerator
Drain pan under ge sideby side fridge
I do not know how to take this pan out
  • 1 more comment
  • lukic Dec 17, 2008
    i called Ge..they told me that drain pan is not possible to be pull out by me!????has to be by technician...i do not agree...we pull the front grid can not pull the pan..we pull fridge from the wall look from the back is anyone knows what to do with the gushing water,it is about 30hours cicle....could be the cloged filter!?how to deal with fridge is side by side Ge older model
    i called the Ge again since i found the problem could be as you mentioned..clogged drain line...i will try..what is O2?thanks ..and wish me luck to solve this issue
  • lukic Dec 18, 2008
    i did clean the dreanage in the fridge waiting for the defrost cycle to happe,in few hours i will know..thanks soooooo much
  • 8,197 Answers
Pull the front bottom grill off then pull the pan out to you to drain or cleas.
Posted on Dec 16, 2008
  • 161 Answers
I bet you have a water filter in the way. I have run into this before where the pan is suppose to come out the front after taking off the bottom grill. The good part is that it is not critical that this pan be removed. The water will evaporate from the condenser coil heat. But, how do you clean the thing which is what I wanted to do. I reached in with a paper towel and did the best I could.
  • Ron Buice
    Ron Buice Dec 17, 2008
    "anyone knows what to do with the gushing water"
    Where is the water coming from?
    If the water is coming from inside the freezer and running out the front left corner. The drain is clogged
    Clogged drain:
    1. Take the bottom drawer out of the freezer. Look at the back wall and you may get a partical view of the bottom of the cooling coils. Directly under the cooling coils is where the drain hole is located. You may need a licht and get your head close to see the drain hole.
    2. If this drain area is filled with ice then you won't be able to see the drain hole. Use a hair dryer to remove this ice.
    3. The drain tube could be clogged.
    I have some O2 tubing that I put down the drain hole to clear any blockage. Sometimes I put the tubing down the drain, seal up the top around the tube with tape and a little pressure from my lungs clears the drain.
    4. pour a little water down the drain to make sure it's clear
  • Ron Buice
    Sorry, I should have said oxygen tubeing. Any type of small hose that fits in the drain hole.
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
Where is the drain pan located on the GE Side by Side Refrigerator I have looked everywhere! Thanks in advance for your help.
why are you looking for the pan,you shouldn't have to do anything with it.the pan is at the bottom of the fridge behind the front kick plate and on some models there isn't a pan at all/the water drains to the bottom frame or floor of the fridge where the compressor is in the bottom back,the water collects there and the heat from the compressor and condenser coil evaporates the water.remove the bottom back panel,lok for the drain line or if it just defrosted you'll see the water sitting in the frame.what's happening that you're looking for the pan?
Feb 23, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice in bottom of freezer.
empty bottom of freezer and run a hair dryer to melt the ice and clear the drain, there is a drain that goes to a pan under your fridge that evaporates the water, make sure your pan heater is in fact wired up, as the factory sometimes leaves these pan heaters disconnected to get the energy efficiency rating for sales.
Oct 10, 2009 | GE GSS20IEP Side by Side Refrigerator
GE build-in sideby side fridge problem
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Water leaking out on floor
there is a drain hole in the back/bottom of the freezer, check if the fridge is connected to a drain and water drains into the hole, looks as if it is cloged.that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrigerator. (where the air blown over it will cause it to evaporate)
Feb 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25JF Side by Side Refrigerator Logo
1,523 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
