Question about Frigidaire ATF6000ES Front Load Washer
My siemens washer will not pump the water out or spin
My siemens washer will not spin or pump the water out. it fills ok but wont pump ive checked all the filters and there not blocked, do you know what else it could be. thank you
siemens siwamat 1060 washing machine if thats any help
  • Anonymous Mar 17, 2014
    washing machine wont let in water
  • 8,197 Answers
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
Why wont my maytag washer fill when door locks? I've changed door lock mech, water fill valves and still does not fill. Is it in middle of cycle?
check for blocked pump some washers wont fill or spin if the controls get a pump motor over amp signal
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2017 | Maytag Washing Machines
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Not taking in water
go back to water vavle and start form there ,,is it humming..verifie water in fill hoses,,check and make sure you have hoses on dispencer correctly,,if removed,,,check and make sure you did not twist or kink hose entering tub...make sure connection are on the water valve..onthejob
Jan 24, 2009 | Hotpoint WMA66 Front Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
SIEMENS WXLM112GB FRONT LOAD WASHING MACHINE
Perhaps the exit hose behind your machine is not at the correct height, about 3 feet from ground. Your pump pumps the waste over this height, into your standpipe or sink; check this out.
Feb 10, 2008 | Siemens WXLM112GB Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,870 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
