Question about Blaupunkt Car Audio & Video
Can an amp be connected to my peugeout stereo, clarion rd3
  • 2 more comments
  • dean7pa Dec 16, 2008
    how do i add an amp as there is no aux output on the back of the stereo? your help would be greatly appreciated
    ok thanks, i dont realy know to hard wire it or make my own with the rca ends, wouldnt know which wires are what,i will have to try and get a diagrham from somewhere
    when you say hard wire it, if you dont mind can you give me a brief description, where do i run the 2 (red and white) phone lead too from the amp ? and the remote from the amp too where ? ect...
    erm... ill see if i can get the model number for you, all i know its a clarion rd3 (blaupunkt) this is my email if it easier for you
    deano.01@ntlworld.com
  • 8,197 Answers
Yes you can add an amp to that radio.
Posted on Dec 16, 2008
  • Jyackle5
    Jyackle5 Dec 16, 2008
    You will have to hard wire it then the old fashion way with the speaker wires.
    The other way is to go get some rca ends from radio shack and make your own if you know how. It will take a little soldering but will work that way.
    Good Luck
  • Jyackle5
    If I see a wire diagram I would be able to help you better. I will try to find one. Can you give me the model #
Need unlock code for my car radio Clarion Model PU 2325A(B) Serial Number CL0410z0167651 Many Thanks?
I need a code for my Peugeout 206
PU-2325a (b)
CL041010270037
PLS HELP.
THANKS.
Apr 25, 2011 | Car Audio & Video
Need to know what the pins are on the connector blocks on a Clarion PU-2358A (peugeot RD3) carv cd/radio
Is this site of any use as it shows many pin arrangements
www.tehnomagazin.com/Auto-radio-car-connector/CLARION-Car-Radio-Wiring-Connector.htm
Jan 01, 2011 | Car Audio & Video
Radio code for clarion rd3-01,serial no
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with C7000000 + + + +  on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Nov 10, 2009 | Car Audio & Video
got it off the garage who serviced the car,thank you for your help.
Sep 30, 2009 | Clarion RDB325D
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
Sea ray boat Clarion stereo and amp
Unless a fuse is blown, there's a problem with the wiring or you have a defective component, there's no reason the amp shouldn't come on. You need to confirn that you have the proper voltage at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
May 23, 2008 | Clarion Car Audio & Video
Station storage
Have you conected the stereo to 12v + before the key? If you conect the stereo after the key it will not get 12+ to the memory. It needs constant 12v+ to keep the memory...
Oct 18, 2007 | Car Audio & Video
Car Audio & Video Logo
204 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
