that specific flashiing is the software in the computer, the television has inside
you need to go to the philips website and download an upgrade software repair it is free-- put it on a thumb drive without any other things on it---- the television ,must be on to install --- turn it on with the remote and then insert the thumb drive-- the television will run a scan--- then turn off television and wait a few minutes-- turn it back on with the switch on the side of the unit-----
the power problem is something else--- the power board sounds like is going bad--- a new one is around 300-400 and a rebult unit is around 100 --- you can find them on partstore.com
this television is poorly built -- when you get the new board it is easy to install -- before ordering a new board -- check the fuses on the board-- there are two fuses -- one is 1amp and the other is 5amp -- both are slwo burn fuses
I had the same problem with the same model. I took off the back of the television and checked the two small fuses. They were fine, unfortunately. So I bought the refurbished power board from Best Buy using the part number that I found on the web. Swapped out the board and the TV works fine. Now I need to know what to do with the old board. I feel badly throwing it away since it is probably some simple part.
I have a Philips Flat Screen Model # 37PF7320A/37 and I am having a problem with the menu screen...
(More)
I have a Philips Flat Screen Model # 37PF7320A/37 and I am having a problem with the menu screen constantly being displayed onthe screen and cannot be removed. No matter what you do, it pops right back on automatically. When you scroll down and hit the exit button, it goes off and comes back on within seconds. When you turn the tv off and on, the same thing happens. I am unable to use my tv because of this. I constantly press the buttons on the side of the tv to try to get the menu screen to be removed and to no avail. I have been doing all of this manually and without the remote. Please advise as to how I can get this removed and use the tv. Thank you.
Hi, I got a Philips 37 inch LCD model 37PF9431D/37 that shut offs by itself and the power LED blinks...
(More)
Hi, I got a Philips 37 inch LCD model 37PF9431D/37 that shut offs by itself and the power LED blinks red a single time followed by two fast blinks. Problem is similar to the ones described by other people here. Any hints? Do I have a bad power supply? Any idea how I can get a service manual and schematics for this model?
Appreciate any help. Thanks.
Philips 37pf7320a/37 menu keeps popping up. a repairman told me its the ssb that runs $600 to fix....
(More)
Philips 37pf7320a/37 menu keeps popping up. a repairman told me its the ssb that runs $600 to fix. could this be true? can I do it myself ?
