Question about Canon imageCLASS D320 Laser Printer
I do not have a manual. What does supply REC. paper mean?
    President:
  • Canon Master
  • 1,447 Answers
Supply rec paper mean stay paper in copier cassette or that the paper print
it is mean insert paper in cassette
Posted on Sep 07, 2009
  • Sazeed Computer
    Sazeed Computer Sep 08, 2009
    please insert paper paper box or paper tray
    photo copy must be use page setup free size
    computer print copy stup a4 or legal
  • Sazeed Computer
    Sazeed Computer Sep 12, 2009
    rec paper mean which paper that make a copy
    Problem Solver:
  • 18 Answers
It means add paper to the paper tray.
Posted on May 29, 2009
4 Suggested Answers
SOURCE: supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Posted on Apr 16, 2008
SOURCE: Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Posted on May 06, 2009
  • 6 Answers
SOURCE: msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Posted on Sep 28, 2009
What does supply rec. paper mean in the LCD display
Your machine is not feeding paper correctly. Check for any obstruction in the paper path
Mar 27, 2015 | Canon imageCLASS D760 All-In-One Laser...
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec. paper when i insert paper then rec. paper jam
Your copier feed roller clought is not active wash it and then solve
Jun 11, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
"Supply Rec. Paper Tray : LTR"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Canon d680
try new cartridge. are you using new or remanufactured?
Nov 09, 2007 | Canon imageCLASS D680 Laser Printer
Canon imageCLASS D320 Laser Printer Logo
862 people viewed this question
old marine
old marine
