Question about Minolta bizhub 200 All-In-One Printer
Here is the manual for it
http://kmbs.konicaminolta.us/productsattachments/manuals/Userbizhub200250350PrintOper.pdf
And here is some more usuful stuf
http://kmbs.konicaminolta.us/content/products/models/bizhub200.html?info=Manuals
I hope that helps you solve your problem
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 16, 2008
Jun 04, 2014 | Konica Minolta bizhub 200 Printer
Dec 17, 2013 | Minolta bizhub 200 All-In-One Printer
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
Aug 15, 2012 | Minolta bizhub 200 All-In-One Printer
Feb 20, 2012 | Minolta bizhub 200 Copier
Sir/mam check the right side door that you open to remove the image unit check that the two latches that hold the door close are OK especially the rear one. Close up. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover with the machine on use a small screw driver and gentle depress the small black switch the machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. Code will come back but now press the Utility/counter button should see button that say maintenance mode press that see trouble reset press that machine again will go thru warm up procedure will see the "." DO Nothing! Should go to "Ready to Copy" if the code comes back have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. Can catch on fire! That will ruin a perfectly good day!!!!
Jan 23, 2012 | Minolta bizhub 200 Copier
Mar 18, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 09, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Apr 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Dec 01, 2008 | Office Equipment & Supplies
103 people viewed this question
