My comp says code 39 can you help - Computers & Internet
  • drushan Apr 10, 2009
    I hope that the above image will help you find A solution to my problem... thanks
    President:
  • 1,257 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
GET YOUR PC PROBLEM FIXED
Posted on Jun 27, 2009
    Sergeant:
  • 324 Answers
Code 39 Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)Cause
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolution
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
I am sending you a copy of this information in the hopes that it will be of some help in your situation.
Cheers!
Ron.
Posted on Dec 16, 2008
I'm reinstalling Windows 7 on my ACER laptop. I need JUST the DRIVER. A wizard wont work since the comp isn't running yet. swingdav10@yahoo.com
If you install the Windows 7 disk it should install generic drivers, then run ALL the Windows Updates.
Mar 22, 2013 | Computers & Internet
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
My poker can't open, what's the problem
I have a few suggestions, 1)Update to the current flash player many of these require current version of flash2)Restart the Comp.3)Run a Scan on your Comp mabey something is causing it to act this way or a virus?-Hope this helps
Apr 03, 2012 | Facebook Social Network
Slow comp!!
Adding more RAM can speed up a Laptop.
Feb 24, 2012 | Dell Computers & Internet
Now my comp.in the shack will not connect to my internet after installing swithch can connect with others fine
Make sure the comp in the shack is using the same gateway the others are using. It may be hard coded for a different gateway.
Open a command window, type "ipconfig /all" (without the quotes), then hit Enter. Look for the gateway line. Make sure it reads the same as the gateway on the computers that can connect. If it does, then look at the DNS lines, and make sure they're the same.
If you need more help, reply with the contents of this computer's ipconfig return, and one of the ones that can connect.
Jul 06, 2011 | SMC 5 x 10/100/1000Base-T LAN - Ethernet...
They are putting the car true a comp to check what is wrong with the car ,but the mecanic that is doing it need one spicific code for the lancer ,to put in the comp to check the car can you help?
Without knowing the make and model of the analyzer they are using, there is no way to help you.
The maker of the analyzer may have a web site where you can find codes missing from the manual they have.
Sep 02, 2008 | Mitsubishi Lancer Cars & Trucks
ERROR CODE 39
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 22, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
