Question about Kenmore 24902 Top Load Washer
Cleaning a stinky washer
I need to open a kenmore washer model 110 in order to clean the inside mold so that I can get rid of the odor how do I go about doing this?
  • 640 Answers
You dont need to open this unit,,,you should have been instructed when you brought unit,,,how to clean it...now fill unit with 1 pint of bleach..hot wash .cold rinse normal cycle..if you never was cleaned do this two days in a row,,,then once a month there after...large fill...buit if you have to get in it remove two screws flip consol remove the two clips and pull cabnit toward you..then remove tub ring...careful trying to clean side of tub
Posted on Dec 24, 2008
There is like a black soot substance coming through into my wash, I'm having to wash the clothes again
When it comes to doing laundry, many people use front loaders because they are more efficient than top loaders. On average, they use 40 percent less water and almost 60 percent less energy. They also clean clothes better. They are not without their problems; and so, if you want to avoid problems, you need to know how to clean a front loading washing machine.
Dangers of a Dirty Washing Machine Mold is a common and dangerous problem with front loaders. Mold and mildew, at best, can cause bad odors in the machine and on your clothes. At worst, mold can make you sick. It grows because dirt, lint and water gathers between the seal of the machine's tub and door, thus creating the ideal atmosphere for the breeding of mold, mildew and other bacteria.
The mold creates inhalable spores, and the bacteria create nasty odors. Inhaled toxic mold spores can cause chronic fatigue; dizziness; eye, nose and throat irritation; fever and flu-like symptoms; headaches; learning disabilities; nausea; severe breathing problems and vomiting. Therefore, it is important that you keep your front-loading washing machine clean and that you keep the area between the door and the tub dry when not in use.
How to Clean a Moldy Washing Machine
If you are wondering if your machine is moldy, it probably is. If you smell a musty, sour or stinky odor coming from your washer or your clothing, you probably have an issue. There are a number of possible solutions, and none of them work for every situation.
Some people have had luck getting rid of mold by changing detergent. Some do well by using a mixture of baking soda and vinegar every few loads. Others have had mixed luck with oxygen-free bleach.
One product many people have had success with is the all-natural Smelly Washer Cleaner product. It works with high-efficiency front-loading washers, and because it is made from citrus, it is safe for the environment. It supposedly cleans by getting rid of the odor: not by masking it.
Another product that is supposed to get rid of the odor rather than mask it is Affresh Washer Cleaner for High-Efficiency (HE) Washers. The manufacturer also claims that the product is eco-friendly and safe for septic systems and appliances. It works by releasing oxygenated bubbles that remove residue buildup that causes odors.
To clean your washing machine without commercial products, use the Acidic Cleaner (click here for the recipe) with some sprinkles of baking soda to clean the rubber door gasket. Try using a soft toothbrush, or one of many small brushes you can find to clean in small crevices, and a soft clean cloth to gently but firmly wipe out the gooey mold. Frankly, If washing the gasket does not get rid of the odor and the mold, you may have to replace the gasket.
Also use the Acidic cleaner and baking soda to clean the soap and softener dispenser. If you can remove the soap dispenser tray, do so, then soak it in the vinegar solution with baking soda for ten minutes and wipe it clean. Also use the solution to clean the hole that houses the dispenser tray, if your appliance has one. Rinse all parts well after cleaning to remove the vinegar and baking soda residue. Spraying just the Acidic cleaner over the surfaces will remove the baking soda, and then water will remove the vinegar.
Again, be sure to rinse and dry everything well. In fact, you should dry all the parts of the machine, including the inside of the door, after each and every use to prevent the growth of smelly mold. Just like we advise after taking a shower to dry the tiles and grout right away, or after cleaning kitchen surfaces to let them dry completely, we advise the same treatment for your front loading washing machine. Mold, mildew and germs like moist surfaces. Eliminate the moisture, and there goes the gunk!
Another part of front loader maintenance is filter cleaning. Manufacturers and models vary, so you need to check your manual for your specific instructions. But typically, it involves opening a small door near the bottom at the front of the machine. Inside, you will find two items: a small hose and a debris filter.
The hose drains leftover water out of the washer, so you need something for the water to drain into. Be prepared, because it might be several gallons worth. After you drain the water from the machine, remove the housing for the debris filter by turning it counterclockwise. Once it is out, clear it of lint and other debris. Before reinserting it, reach behind where it was and check the drain pump impeller with your fingers to be sure it is also clear of debris.
After you have cleaned the above items, run a load of hot water with laundry detergent but no laundry. Adding oxygen-free bleach to the detergent will prevent mold. If your system has an integrated cleaning cycle, use that. If you were having odor issues, run another load afterward using hot water with one cup of baking soda and one of white vinegar.
How to Prevent Mold in a Front-loading Washer In addition to the rubber door gasket, you need to clean the soap dispenser and any other part to which you have access frequently. Because front loaders use very little water, not all substances are rinsed away when the tub empties. This can cause a residue buildup.
Let it Dry!
It is good to leave the washer door open after doing a load. This allows the inner parts to dry out. Dry the soap dispenser and the door gasket by hand with a towel. Also, do not leave wet clothes in the machine for very long - especially all night. Any moisture in the machine will eventually cause mold.
Rather than using powdered detergent, use liquid because it dissolves better and leaves less residue. Also, to reduce residue, use as little detergent as you can while still getting a clean wash. Rather than liquid softener, use softener sheets to reduce moisture.
If you always wash in cold water, do an occasional load in hot water. This will clean out some of the residue buildup. Use a low-sudsing detergent designed for a high-efficiency washer. These washers usually have self-cleaning cycles, and you should use the one on your machine periodically.
As with anything, prevention is better than cure. Becoming a little slack in caring for your front loading washing machine can cause many problems later. And if you are no more fortunate than many other people, you may not be able to get rid of your problems once you have them. So if you haven't done so in a while, go take a look at that washer and get ready for action.
Aug 02, 2015 | Washing Machines
Where is the filter on the series 70 washer? my washer has a stinky smell and someone suggested it may be a filter that needs to be cleaned.
clean the door boot carefully with bleach if mold grows in the lower door drain holes it will mold and stink,you will see black spots on the boot,thats mold
Sep 11, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite smells like mold!
Run a cycle ,no clothes in, with about 3 cups/ 750 ml of bleach in it. How? put a fil a plisticbag with the bleach and set it in the washer. It will tip up when you start the cycle. You should end up with a clean washer and clean empty bag.
Jun 27, 2010 | Kenmore Elite 45986 Front Load Washer
The rubber hose around the inside door get dirty
wipe it down with 1/3 to one gallon of water and leave the door open when not in use.
Jan 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag HE 4t/ Kenmore Elite Smartwash Serial# CST0411376 MODEL# 11045088403 TYPE 199 712 CN/AP MY WASHER HAS A AWFUL ODOR INSIDE THE TUB. I HAVE CLEANED IT OUT WITH ALL KINDS OF CLEANERS TO TRY...
The following link provides guidance on how to maintain a front loader to keep the mold, mildew and odor away:
These are recommendations provided by the manufacturer. Most important of all, keep the rubber bellow clean and clear of debris and make sure you leave the door slightly open when not in use. This will minimize the build up of any mold or mildew and allow the tub to air out. The odor typically comes from the the residual water that stays in the wash tub under the basket and small articles of clothing getting stuck in the rubber folds of the door bellow. (I once found 17 socks stuck in a customer's washer and they wondered why it smelled so bad). NOTE: It is NORMAL to have residual water in the wash tub. If you do not routinely use a hot water setting, run the washer on a sanitary cycle about once a week, or so, with a small amount of bleach to get rid of any bacteria. Since some users conserve and only wash in cold water, they do not bacteria get rid of any bacteria inside the wash tub. I personally own one of these washers and have never had any odor or mildew problems in 8 years by following this simple advice. If you have any further questions/concerns please let me know. I hope this helps you.
Aug 06, 2008 | Washing Machines
Ac odor
clean the ac with coil cleaner make sure to wash it off with water very good .
Jun 24, 2008 | Comfort-Aire RAD-81 Air Conditioner
Kenmore Washer Odor
Meoser,
I've been selling the only available all natural washing machine and towel mold and mildew remover online at smellywasher.com since 2006.
It's now also available at Ace, Tru Value, Hardware Hank and Do It Best hardware stores. One bottle provides 24 treatments and guarantees to remove mold, mildew, or any odor from your washer. After the washer is cleaned it also safely and easily gets rid of the mildew smell from any towel or clothing that the odor has transferred to.
The dark, moist environment of your clothes washer is the perfect place for mold and bacteria to grow. See: http://www.cbsnews.com/video/watch/?id=5408971n
We can't change that environment but we can stop the food source for them to grow buy reducing the amount of detergent used and stopping fabric softener use. Go to the blog page at smellywasher.com to read advice on the cause of and cure for washing machine and towel odor.
Nov 06, 2007 | Washing Machines
Kenmore 24902 Top Load Washer Logo
103 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
