Question about VinoTemp (VT60GNV) Wine Cooler
Vinotemp not cooling
Help!!!!!  Need to have cold wine for Christmas.
Our vinotemp keep "clicking" on like the cooler is going to come on, but the temperature stays at or above 70 degrees even though we have it set to 50.  Any advice?  Should I call someone out to replace a part, can I fix it myself or would it be just as expensive to but a new one?
Thanks
  • 3 more comments
  • Anonymous Jan 24, 2009
    I have the EXACT same problem.  What should I do?
  • lchingon Mar 04, 2009
    I have the same problem, display always stays at 76 deg. I traced the schematic and Fan on, display works, fuse ok in interconnect board and the compressor has the 120 volts required. However, it appears that the compressor kicks on, draws the current down to 116 Volts and then shuts off. Looks like the compressor is bad. Replacing it is not possible without someone who can install freon 134A back into the system. I am taking mine to a repair place and of course have to pay the $35.00 fee for them to inspect it again and give me a quote on what it will cost to replace the compressor. I looked for the compressor unit online and can't find that specific LG model, go figure. Will let you know sometime next week what it runs to get them fixed.
  • Mutiny Jan 09, 2014
    I need the capacitor Dave, Ron
  • Mari Severino
    Mari Severino Feb 03, 2014
    is the relay and overload attach to the compresor. qp2-4r7 is part number. replace it and it will work again
  • rosa
    rosa May 27, 2014
    yes you can call it capacitor but its really a relay. qp2-4r7 and over load . change it and it will wor again
  • 59 Answers
You can fix this for $5. You can confirm the problem by taking the back off and see of the red and green led on the circuit board are flashing. They will be steady if the board is ok. The fan is usually just rocking too like it is trying to start. The part is a capacitor and is $5, but you will need to be able to remove and solder this part on the circuit board. If you need the part, just let me know.
David
Posted on May 27, 2009
  • rruda82
    rruda82 Oct 09, 2012
    hi dave where do you get part
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Its the relay overload goes bad. just take cover attach to the compressor then remove it or pull it out. replace. appliancepartpro.com has it. qp2-4r7 is part number
Posted on Feb 03, 2014
  • Melissa Coleman
    Melissa Coleman May 23, 2014
    They don't have the part
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
Posted on Jul 04, 2008
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 19 Answers
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Posted on Feb 21, 2009
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
This VinoTemp vt 60 just quit working. No
if the evaporator coils are warm, you have a leak and no refrigerant.
Aug 25, 2009 | VinoTemp VT-60 Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Vinotemp VT-60 Condenser won't shut off, unit running way too cold
It might be a sensor or control board problem. Any appliance repair place should be able to help you out with this. Or you can try contacting the manufacturer directly for help or if you need to purchase replacement parts. Otherwise, my cheapest suggestion would be to hook the cooler up to a timer, so you can turn the unit on and off maybe every 20 minutes or so. That should help keep it from causing more harm and then you can monitor the temperature with a thermometer. Hope that helps!
Aug 29, 2008 | VinoTemp (VT60GNV) Wine Cooler
Wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
jbarron@vinotemp.com
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
4,944 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
