Question about Hoover Washing Machines
My hoover optima machine model no. HNF 6127 keeps stopping at the rinse cycle
  • Hoover Master
  • 3,463 Answers
Check to see if it is on rinse hold or crease care, if it is this will cause it to stop at the rlnses, also ensure that tjhere is cold water at the valve, a faulty cold inlet valve will cause it to stop,as it will be waiting for cold water.
Plz rate my solutioun.
Thanks.
Posted on Dec 17, 2008
Reset button on hoover inter@ct washing machine hnf 9147 z
try this link out you should find how to reset it here-
http://www.manualslib.com/manual/644650/Hoover-Hnf-9167.html?page=37
Sep 26, 2015 | Hoover Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
My hoover optima washing machine model no. HNF 6127 keeps stopping when it gets to the rinse cycle
Make sure it is not on rinse hold or crease care, release if it is, make sure pump is working, and that the cold inlet valve is working., all of these things could prevent it from completing rinse cycle.
Plz rate this solution.
Thanks.
Dec 16, 2008 | Hoover Washing Machines
Hoover 550 MA Top Loading Washing Machine
if if spins the belt is ok,may have timer fault or timer module ( next to timer) if fitted will be faulty
Mar 24, 2008 | Washing Machines
Washing Machines Logo
207 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
