Question about Coby DP-768 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Wood Frames
My digital photo frame won't recognize my jpg files
It tells me they are the wrong file format and refuses to play them.  However, if I keep the jump drive in long enough, it automatically starts to play the photos as a slide show.  There has to be a better way to start the slide show than waiting through error messages and blank screen before anything happens!  Also the play button doesn't work - none of the controls work.  It just plays the pictures as it sees fit and when it sees fit!  I have no control over it at all!  Help!
  • Anonymous Jan 14, 2009
    help
4 Suggested Answers
  • 121 Answers
SOURCE: i am having a problem with my digital photo frame
you can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
Posted on Oct 28, 2009
SOURCE: Cannot get AVI or MPEG
You need to convert the video with a resolution of 240x120 in AVI or MP4.
Thanks, Sandeep.
Posted on Sep 19, 2010
Testimonial: "should have come here first. Would have saved a lot of time and aggravation. Many thanks to Sandeep"
  • 102366 Answers
SOURCE: I have a digital photo
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Posted on Dec 05, 2010
My daughter was playing on my laptop and now i'm locked out and don't remember my password, how do i reset HP EliteBook 8560p
Dear Ms / marvin james
you have to get SMC.bin It is formatted specifically for my machine, has to match the UUID. Copied file to FAT 32 formatted jump drive
tell hp the problem
Regards
Apr 23, 2015 | HP Computers & Internet
Tip
How to convert MVI to AVI file for edit in Pinnacle Studio?
Some Canon digital still cameras (Powershot A75, A63, S410 etc), are capable of shooting a limited amount of video, since there is no tape, it is saved as an MVI file format. However, the MVI file format is not compatible with other programs. Even windows media player refuse to play MVI file. Besides, editing software like Pinnacle Studio and Windows movie maker do not work with the format. Because of this, the files need to be converted to a format that is more widely used, such as AVI so that these videos shot with still camera can be played and edited as easily as other common videos. This guide is to tell how to do that.
Software you'll Need: Pavtube Video Converter
Step 1. Download Pavtube Video Converter, and follow the prompts to install the program. Click "Finish" when the installation is complete, and Pavtube Video Converter will launch automatically.
Step 2. Click “Add” to load MVI files or directly drag the files into file list. By default, the files are selected. If you would like to join all the selected files together, check the box of Merge into one. You could view the files in preview window, simply highlight the file and click play button.
Step 3. Click “Format” bar to determine output format. Follow Common Video-> AVI Video (*.avi)/ DivX AVI(*.avi). Click “Settings” if you’d like to customize advanced audio and video parameters like Video Codec, aspect ratio, bit rate, frame rate, Audio codec, sampling rate, bit rate, channels. Do not forget to click “OK” to confirm your settings. Then type in a desired output location in the "Output" box.
Step 4. Click "Convert” to start converting MVI files to AVI. You could set auto shutdown in progress window or leave it there and come back later. After conversion you could edit the converted video in Pinnacle Studio, and make a film out of it or burn it onto DVD.
Learn more: http://www.pavtube.com/guide/convert-mvi-to-avi-for-edit-in-pinnacle-studio.html
on Mar 25, 2010 | Cameras
My lg arx8000 home thearter is not playing files from my external hard drive
Probably a format issue.
Not enough info
It's like saying My car won't start and not saying the gas gauage reads empty.
Apr 01, 2014 | Western Digital My Book Essential Edition...
Keeps telling me to format it
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Feb 15, 2011 | Western Digital WD Passport 250GB Portable...
When i delete all the files off of my jump drive it says that they are still on the jump drive, and that there is no free memory space available. How do I free up that space even though I deleted all the...
control panel administrive tools ,computer management disk management right click on your drive select properties click tools you should see check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then you can select the drive and defragment it
you can also format the drive right click select format
note: this will remove any data you have on this drive
hope this helps
Dec 27, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I own a WD MyBook. It refuses to connect to the PC, though the hard-drive remains on whilst the power adaptor is plugged in. It cannot however be turned off via the green-lit power button. When the...
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty/faulty hard drive give your hard drive a firm tap on the side this should free up the reader arm
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead using a multimeter
or
control panel administrive tools,computer management disk management right click on your drive select properties click tools you should see two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Dec 04, 2010 | Western Digital My Book Essential Edition...
Seagate Hard drive
Remove the harddrive where your files are save then try to open it in another PC if problem persist there something wrong with your harddrive. Try to format your harddrive then after formating use a software that recover your files but im not sure that all files will be recover im 50/50% you you dont have that program I have some just ask assistance. But if your drive is ok then your files is also there. There is something wrong with OS matbe it is attact by a virus.
Jan 07, 2009 | Computers & Internet
Reformatting songs/mp3 player
The Sandisk site says that your dad's device should play .wav, .mp3 and .wma files. Has the player EVER worked? I got a C250 for my wife as a Christmas present and my computer recognized but refused to communicate with it UNTIL I DOWNLOADED AND INSTALLED THE FIRMWARE UPDATE. The player was a paperweight until then. It turned on and played the demo files pre-loaded on it, but I couldn't transfer a single file into it. Just a thought. Here's the link:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
good luck.
groove_guy
Jan 01, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Format problem
If "format error" is flashing, the format of the file system is wrong - it needs to be reinstated as Atrac3 file format. I'm guessing you formatted it using the option on your computer. I've had this problem with my Sony NW-E105, and fixed it. Turn on the player, and press your menu button. Scroll over until the option displays "format", and then select that.
Oct 12, 2006 | Sony NW-E105 MP3 Player
Coby DP-768 7-Inch Widescreen Digital Photo Frame with MP3 Player & 2 Wood Frames Logo
64 people viewed this question
Top Coby Photography Experts
RudeRude
Torashi
Are you a Coby Photography Expert? Answer questions, earn points and help others
