Question about Lexmark P6250 All-In-One InkJet Photo Printer
Horizontal white lines
When I copy the page is full of evenly spaced white lines, I am sure it is a simple maintence issue, but what part(s) needs cleaned?
  • 3 Answers
Go to the maintenance link for your printer (in properties) and clean your nozzles. It could be this, bad or low ink or needs alignment.
Posted on Dec 16, 2008
Image distort when copying and horizontal lines
Getting caught? Loose paper shred inside feeder?
Mar 28, 2014 | Canon D320 imageCLASS Digital Copier
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
Printer prints white thick blank lines
1- black lines are from the drum: it has burnt out on that particular spot and rotates
2- the white horizontal gap space if it is not you skipping space is also from the drum
3-the white Vertical is most likely from the developper (unit that has the toner and is against the drum, look at the roller it should be solid black, maybe there is something on it : hair paper etc....
Aug 25, 2008 | HP LaserJet 1020 Printer
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
Lexmark P6250 All-In-One InkJet Photo Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
