SOURCE: very slow 2nd hand peg perego gaucho
I have the same issue. Called their customer service and they said it was a defect in the charging system. They are sending a upgrade kit for free, but when it's installed you can't charge the battery using the rear port anymore. No big deal. I'll report back when the fix is complete. 5-7 days until it gets here.
SOURCE: cant find the charger for my peg perego battery
I would use the specific peg perego charger. I had a neighbor who used a different one and he ruined his battery.
You can purchase them at this website I found http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
Hope this helps
SOURCE: my sons peg perego john deere jeep only sets off
I would get the Peg Perego Gator Shifter Assembly from http://www.shopjandl.com/
Make sure the wires are secure on both motors in the back.
One time I had the same problem and I had loose wires on the motor, but I ended up replacing the switch assembly later because it would only work in 1st gear.
Hope this helps
SOURCE: Peg Perego Gaucho Rock'in Worked for a minute than Stopped.
it sounds like a fuse is cutting it off.
I would contact the repair help at
They always help me with my repair problems.
hope this helps
SOURCE: new battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
