Question about Xerox Phaser 6250DP Laser Printer
Xerox 6250 Where can I find the information from Xerox about the "snippet" to fix the printer? I looked on their website but couldn't find any info. I even looked up Whitt's company and sent an email but never got a response.
  • Anonymous Mar 26, 2009
    our phaser 6250 is connected with our seamens gamma camera computer, after we installed the new imaging unit , transfer roller and fuser the the prints changed orientation, i have tried to set it on the computer and printer and still the problem persist
It was an email we were sent from Whit. We can forward it to you if you'd like.
email us at: lasersaver at sbcglobal dot net (format correctly of course) and we'll send it to you.
Put "Snippet" in the subject line.
Posted on Dec 16, 2008
How do I find the page count for the printer
Phaser 6250 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-6250/support/enus.html
XeroxProduct support for Phaser 6250. ... with our support knowledge base directly, and troubleshoot itself. Automated Remote Diagnostic Tool - PhaserSMARTâ„¢ ...
Oct 02, 2015 | Xerox Phaser 6250DP Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
How do you use photo paper in a xerox phaser 6250?
If you want to use photo paper for your Xerox phaser make sure the photo paper is meant to be used in your printer. The best paper would be the Xerox brand photo paper which is made to be used in the Xerox phaser printers. You use them like normal paper and print your document or image onto the paper. If you cannot find the paper that works with this xerox printer go to the Xerox website and under supplies, then entering your printer model it will give a list to the paper recommended for this model.
May 27, 2010 | Xerox Phaser 6250 Laser Printer
Xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
6250 Jam
Go to the Xerox website and select the drivers tab. Select the 6250 and search for the firmware for > Firmware Updatethen follow instructions
Dec 04, 2008 | Xerox Phaser 8500/DN Printer
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
139 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
