Question about Canon Speedlite 430EX TTL Flash
The normal flash will not work
After using my Canon Speedlite II for the first time, my regular flash for the REBEL XTI does not seem to be functioning. Is there a setting that must be swtiched back to enable the regular flash?
  • 685 Answers
The camera in P mode does not allow the pop-up flash to work until you turn it on. Make sure the camera is in green box mode and if the flash does not work then the camera will have to be sent to canon for service.
Posted on Nov 24, 2009
Flashes Canon 200E and/or Canon 430EZ + Rebel Xti or Canon G-10
No. You will need an EX series flash like the 430EX or 580EX. Those designated as EX II will also work.
Feb 20, 2010 | Canon Cameras
I just Bought a Canon Speedlite 540EZ it will not fire in the hot shoe of My Rebel XTI are they compatible
No. The rebel, or any digital canon camera requires the use of the EX or EX II series flashes.
Jan 19, 2010 | Canon Speedlite 540EZ TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Xti and Speedlite 200E
The only way to solve the problem I see is to turn the flash into non-TTL one. It can be easy done by opening four screws at the connector side of the flash, unsoldering or cutting the BROWN line and closing the connector back. The AF assist led will work.
That I did on my 200E with Canon 400D camera and all works file.
Enjoy!
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash doesn't work
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 02, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Old flash
at a whopping 46.6V.. yes, it would damage it.
Nov 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Not working with my Rebel XTI
ALL Canon digital EOS cameras will work with E-TTL only. Solution: you need EX flash for full auto.
Oct 20, 2006 | Canon Speedlite 540EZ TTL Flash
Canon Speedlite 430EX TTL Flash Logo
205 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
