I cannot install windows xp pro serv pack 2
Abit kn8 sli mother board,new hard drive, cd burner floppy 3.5
When i try to install windows xp pro i see all configuration then it freezes error message windows could not start because of a computer disk hardware config problem.
I set my bios according to users manual.
can you help me.
Charles
  • 2 more comments
  • cjohnson1241 Dec 16, 2008
    Yes my hd i sata it is showing in bios.
  • cjohnson1241 Dec 17, 2008
    I install hd drivers and there is no change.
    Irecieved the comment about t boot i cannot go to start or my computer without installing windows xp pro.
  • cjohnson1241 Dec 18, 2008
    During start up i see cpu, cd and hd so the drivers are loaded. if you dont have a soluting i requesting a refund.
    thanks charles
  • 928 Answers
What kind of hard drive are you using. Are you using a SATA hard drive? If so you have to install the SATA drivers for the hard drive so that the Windows XP Pro can detect it.
Posted on Dec 16, 2008
  • 365 Answers
I think this may be the problem due to the damaged CD which does not contain all the necessary files which is to be installed .in this case the windows does not recognize a hard disk and the setup could not be completed.try to install WINDOWS from a new disk.thank you
Posted on Dec 18, 2008
    Scholar:
  • 86 Answers
See if it tells you if you can press a certain button for a Boot Menu like F-10... You might have a corrupted CD or maybe even bad RAM... Try an Ubuntu Live CD if possible and do the RAM Check.
  • Sudo Bash Dec 18, 2008
    It is either SATA Drivers, RAM, Corrupted Disc, or maybe you have the jumpers on your cdrom wrong... Just go ahead and put the jumpers on all your cd-roms on Cable Select.
  • 104 Answers
Freezing with a blue screen error can also be caused by bad memory. If you have any spare memory you should try out
Best Luck!
Posted on Dec 17, 2008
  • 1,879 Answers
The XP installer lacks updated SATA drivers.
creating a boot disk with updated driver also depends on the motherboard chipset.
follow the link Ekse provided.
  • 1,183 Answers
HI,
The problem can two things , something connected inside the computer is not compatible or something connected outside .
1. Make sure disconnect everything outside the computer except for keyboard mouse ,monitor and power cable
2. In the inside make sure RAM memory is seated correctly, and is in equal pairs if there are more than one memory sticks
eg. if you have 1.5 gb ram with one 1 gb module and one 512mb module , make sure you disconnect 512 module .
3.Check installation media cd
4. If your sata harddrive has come with the cd for installation of drivers make sure you install the same , by pressing F6 , when window is loading
Also if you could mention excatly on which screen your system is hanging
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Dec 19, 2008
    The solution to your problem is replace the harddrive on the unit , the hardrive that you are putting in requires add on drivers in xp. Try changing the harddrive maufacturer . The issue would get resolved for sure.
    Thanks
    proton
    President:
  • 2,110 Answers
Try to enable SATA hard disk in BIOS...
try to install wiith Windows XP SP3 bootable CD...
u can find it here
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
    Sergeant:
    Novelist:
  • 327 Answers
This behavior can occur if any or some of the following conditions are true:
  • The Default value in the [Boot Loader] section of the Boot.ini file is missing or invalid.
  • Windows XP is not installed in the location specified in the Boot.ini file.
  • The Ntoskrnl.exe file is missing or damaged.
  • The partition path in the Boot.ini file is not set correctly.
  • General hardware failureMethod 1Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base:
289022  How toedittheBoot.inifileinWindowsXPMethod2Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file: Use the Windows XP CD-ROM to start your computer.
  1. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  2. Select the Windows installation that you want, and then type the administrator password when prompted.
  3. Type bootcfg /rebuild, and then press ENTER.
  4. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional orWindows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER].After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base:289022  How to edit the Boot.ini file in Windows XP---Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeNote In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
  8. Method 4Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /rswitch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch.
f th
  • 679 Answers
Did you re formatt the drive, and is this a new build? If so, you need to format the drive prior to installing Xp , ok first from the bios set "boot from cd/dvd drive", then it should restart from the XP disk. Once you see it do that just follow the directions, it will run you through a "quick format" then insatll XP, let me know how u made out, thanks, peace, GYM
  • George Bill
    George Bill Dec 17, 2008
    I have done this on systems many times, are you able to get into the bios, that's the first thing, if you can then you can set the boot priority of the drives, right now its probablly 1,floppy,2cd,3HD, switch the order to boot drom CD/DVD drive. Restasrt and make sure you have the XP disk in the DVD drive. From there just follow the directions, if you can get this far, you are golden. From there you can formatt, and install, good luck Gym
  • George Bill
    Here's what I think, If you purchased this computer with no operating system disk. Then there is a good chance that it may have pireted software. There is no way for the user to know this. If you are going to microsoft or windows update, and it is freezing from there over and over again and you don't have the disk or the serial, it won't let you install the update. Unfortunately, other than hacking the system, which is illegal, you are really stuck. I would recommend calling the person who sold you the system and asking them for the serial number, otherwise you need to format and reinstall, I can help you with that part once you get the disk.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try to set the CMOS/BIOS to default either by the jumper or remove the battery (for about 15 minutes). Thereafter, just change the day/date/time. Verify that the CMOS could auto-detect the hard disk. Additionally, if the HD & CD burners is ganged on a singled IDE, pls verify that the HD is set as MAster and the CD burners as SLave.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 16, 2008
    A few additional thoughts:
    if the HD is SATA, pls enable SATA controller and/or try either on/off RAID;
    there were some issues with Maxtor HDs on nF4 chipset;
    have you tried the F6 option?
  • Louie  Role
    Louie Role Dec 17, 2008
    Could you try using another hard disk, even smaller either SATA or IDE. This is to determine if the chipset does not like the new SATA HD.
  • 13,433 Answers
is your hard drive SATA? does the setup copy the files or how far to you get actually?
  • 112 Answers
Hello sir,
i hope you are very worried about it
now be free
this problem is in your CD are DVD that you use for installing in use a new cd
are try to repair you OS
Trying to install new HDD and OS (XP-Pro). System boots from CD just fine until it gets to "Starting Windows". When it get to the window where you are prompted to Install Windows XP or Repair, the...
replace leads that attach from your motherboard to hard drive
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 24, 2010 | Abit KV7-V Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
KN8-Sli Video Won't work..Checked Power & Graphics card
Bios upgrade on the board, or video card. And have you had the mother board checked to make sure all the caps, v-regs and everything are fine?
Jul 28, 2009 | Abit KN8 SLi Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=KN8+Ultra&pSOCKET_TYPE=Socket%20939
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
No boot
if you had received a cd with the card that contains drivers i would replace the old vga card and, assuming it boot s okay, load the CD. after this shut down, swap cards, then reboot.
Feb 07, 2009 | Abit KN8 SLi Motherboard
''Unable to read from disk or disk error, press ctrl+alt+del to...
Try new hard drive. Its faster than messing with all this.
Dec 23, 2008 | Abit KN8 SLi Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit kn8 sli motherboard won t boot up
PULL OUT THE WIRE FOR A POWER SWITCH ON THE BOARD AND TRY TO SHORT BOTH PINS WITH A SCREWDRIVER
Oct 17, 2008 | Abit KN8 SLi Motherboard
Computers & Internet Logo
658 people viewed this question
David Payne
David Payne
