Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan makes noise
Hi - the unit works fine, but the fan makes a noise like its touching something.  It's been like this forever.  How do I get inside the unit to view the fan.  Can't find a manual online.  Ed
    President:
  • 2,692 Answers
Here is the General Electric appliance web site to download your manual from..
http://www.geappliances.com/service_and_support/literature/
Posted on Dec 19, 2008
Hi. I just bought a whirlpool over the stove microwave #UVM6011CB at Lowes. All works fine except fan doesn't work. We vant out the back and did turn the fan to do so. Help?
If this is an overhead builtin unit and you want the unit to vent outdoors and not back into the kitchen, then the fan motor must be reorientated inside the cabinet See your installation instructions.
Nov 11, 2017 | Whirlpool Microwave Ovens
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Fan not working
Fan motor probably went bad...You can try to see if the motor is seized up by taking the cover off and giving the fan a little spin. Make sure you unplug the unit first...If the fan spins by hand but does'nt turn when on then the windings in the motor have burnt up..you can obtain a fan motor from any appliance parts dealer. A word of cautin though...there are VERY lethal voltages present inside especially on the magnetron tube and the big silver filter capacitor inside...DO NOT touch these components as they have the ability to KILL YOU.
Dec 19, 2010 | Microwave Ovens
Since this morning my fridge has been very loud and is getting louder. It sounds like the fan to me as its not constant and it stops when I open the door. Is it the fan? Is this something I fix this...
I remember happening to us many years ago. The cause was accumulated dirt and loose insulation material interfering with the fan blades. The solution was to unplug the refrigerator from the wall outlet, move the unit to enable reach from the back, unscrew the screws holding the back cover located at the bottom area (made of kind of cardboard), with the vacuum cleaner thin long nose attachment clean anything that looks dirty the best you can reach. Look for the fan and check nothing is interfering with it. Clean it, use a thin brush the best you can. Be careful not to hurt yourself scratching a finger or break anything bumping around cleaning. Some refrigerators design allows to reach the condenser panel (kind of a radiator or grilled looking component), if you can clean that too it will get your unit working efficiency back to maximum.
Another cause for noise could be the freezer fan hitting frozen condensate caused when the door gasket is deteriorated or not sealing well (humidity seeps in and freezes interfering with the fan operation). While you are at it look for any freezer stuff (content) sticking into the freezer fan cover and touching the fan, that may make noise too. Good luck.
Dec 18, 2010 | Microwave Ovens
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot turn off fan
the fan has to stay on,thats the way they are made
Nov 30, 2008 | Kenmore 60654 Microwave Oven
XL1800 still works fine but makes a lot of noise while on.
It may be the stirrer in the ceiling area.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Model JES735
Yes, the fan blade is hitting something inside.Usually by opening the microwave, you can slide or reposition the plastic fan blade on the shaft.Probably this happened in shipping to the store where you bought it.CAUTON:make sure the unit is unplugged before you attempt this.Other option is return for replacement.
Nov 06, 2007 | GE JVM1630 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
143 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
