Question about Kitchen Ranges
I have a gaggenau double covection oven about four years old in the all convection position it will not heat past 280 degrees. can you help diagnose the problem
  • krellsid Dec 17, 2008
    the solution i received is from a person who has no idea what these ovens are how about something techncal what are you sell here?
    this is not the problem do you have some one there that truly understands this product !!!!!
  • 19,396 Answers
A gaggenau double covection oven is supposed to reach over 400, if it does not go over 250, then it is probably a faulty thermostat.
If the oven is ventilated (should be) check also if the fan is working.
Posted on Dec 16, 2008
    Sergeant:
    Novelist:
  • 327 Answers
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control. Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 | Ovens
Gaggenau wall oven
hi thanks for the question plus or minus 25 degrees is acceptable the heat will go past the set setting turn off and go below the set setting but the average temp is ok so there is nothing wrong thanks the appliance doc
Sep 27, 2008 | Gaggenau EB388 Electric Single Oven
Neff model U1461
your convection element has blown by one online and replace it yourself
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 08, 2008 | Sharp R-963 Convection/Microwave Oven
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
