Question about Cell Phones
Nokia 6500 slide secret code
Hi Erone,
I bought a used Nokia 6500 slide-1 from Craigslist and I forgot to ask the original owner the secret code. I could not get hold of him after the sale(so typical of Craigslist).
I tried the usual 12345 but it did not work. I can use the phone fine but I wanted to add a layer of security by setting up a phone lock and this is when the problem started.
The bunch of numbers behind the battery are as follows:
FCC ID: QTKRM-240
IC: 661AD-RM240
002108474E6F
Code: 0565060
353547/02/673136/7
Thanks. Any help will be greatly appreciated.
Anton del Rosario
Vancouver, BC, Canada
suraj4us
  • 61 Answers
SOURCE: Nokia 6500c security code reset
Master code for your Cellphone is
5452654303
Let me know if you have any doubts..
Best Regards,
Raju
Posted on Feb 12, 2009
  • 135 Answers
SOURCE: undo restriction code nokia 6500s-1
NOKIA UNLOCK AND OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
Posted on Feb 21, 2009
  • 42 Answers
12345 type on your mobile
Posted on Apr 04, 2009
sonu_sehgal
  • 421 Answers
SOURCE: Nokia 6500c
please give me your imei no
Posted on Jul 04, 2009
  • 229 Answers
SOURCE: RESTRICTION CODE NOKIA 6500SLIDE
Try restriction codes here http://www.mobile-unlocker.com/nokia-6500/rs2wp9/
Posted on Nov 26, 2010
Forgot my security code for nokia 6500 slide
You can use the Master Code to reset the security code, master code is unique for every nokia phone use nokia loxk code service from http://www.nokialockcode.com/
May 12, 2011 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide unlocking on Orange
As it's a BB5 device is very hard to unlock it. Ask your friend to contact Orange for unlock code.
May 29, 2009 | Nokia 6500 Slide Cellular Phone
I have forgetten my nokia 6500 security code?
i have forgetten my nokia 6500 security code
Feb 23, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide - RESTRICTION CODE
you can contact the service provider.........
Feb 14, 2009 | Nokia 6500 Slide Cellular Phone
only way is to HARD reset phone.. take it in to a gsm unlock shop.. see what they can do..
yes i can help you. You need a unblock code from your network as you have blocked your phone
Dec 14, 2008 | Nokia 6500 Slide Cellular Phone
restriction code can only be done by
1. having your phone unlocked
2. request a code calculation based on imei
3. purchase a turbo simm
all three will cost
shop on ebay i found
4onesexpress-07802458019
Dec 02, 2008 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide
hi i just brought a nokia 6500 off the o2 internet and they av sent it me on thew network 3 now the problem is i use o2 anfd voda and it is askin 4 a restriction code can u help?
May 24, 2008 | Nokia 6500 Slide Cellular Phone
hi,
I have Nokia 6500 Slide locked to UK Orange Network.
IMEI Number is 352027027919833
Kindly help with a Unlock code.
Thanks. CAISER NOMAAN
May 22, 2008 | Nokia 6300 Cellular Phone
u have to do update ur nokia phone give it 2 old firmwire virsion den aftr dat u up date new fim wire vrsion
Apr 28, 2008 | Cell Phones
Cell Phones Logo
1,578 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
