Question about Frigidaire FGF366E Gas Kitchen Range
I get an F1 error message when trying to light the oven.
The oven has been taking a long time to light. Sometimes not lighting at all on two or three tries. Alll we wee is the orange glow from the heater coil. It also seems to be taking a very long time to preheat ...
  • 8,197 Answers
An f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Nov 19, 2011 | Ovens
Whirlpool oven timed bake feature dosn't work.
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 25, 2009 | Whirlpool RBS275PD Electric Single Oven
The oven door locks and lock light comes on. It
Flashing F1 clearly indicates a problem in the electronic control, its keypad (which may only be available with the control) or sometimes even the oven sensor.
The first thing you can try is disconnecting the appliance from power for several minutes to see if that clears the problem. If not, some investigating will likely be necessary. However, a defective oven temperature sensor can also sometimes trigger the same F-1 error to display. It is also not inconceivable that an improperly grounded or polarized power supply to the range could also cause intermittent failures of the electronic control. Checking the power supply should usually be done as a matter of course during testing.
Unfortunately, it will likely be difficult to pinpoint the exact cause unless the range can be tested *at the time of failure*. Otherwise just replacing the possible suspect components may need to be done to see if they correct the condition.
Sep 01, 2009 | Kitchen Ranges
Tappan gas range tgf355 error code f1; what does it mean?
Where can I find the manual of the parts of the rear box of a Galloper 4X4 year 2001
Jan 19, 2009 | Tappan TGF320 Gas Kitchen Range
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Frigidaire FGF366E Gas Kitchen Range Logo
163 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
