Re: ERROR - SCREEN SAYS "OUT OF MEMORY, PRESS SET"
The printer comes stock with 64MB of printer memory. On complex print jobs it is not enough.
Pick up an additional 64mb 133mhz cl3 sdram chip (the small size like a laptop memory chip) and it will double the printer memory and help stop this problem.
Steps to Fix Ricoh Printer Error Code SC899:- Start with unplugging the Ricoh printer network cable. Next, enter the service mode. Press the buttons in order as given after, [Reset] https://www.youtube.com/watch?v=ol2FUcWg08k
Hi there This is only some thing you can try it may work. Solution 1:
1. Press and hold "left arrow" key 2. Press the "setup" key and release both keys 3. Press and release the "OK" button 4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button. 5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”, 6. Press and release the “OK” button. 7. Display should say “Hardware failure status: Clear. Press OK to clear”. 8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”. 9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation. 15. If the error is still there, or reoccurs the printer is already defective. Solution 2: 1.Press the On button to turn the printer off. 2.Unplug the power cord from the back of the printer. 3.Remove all the ink cartridges. 4.Wait two minutes. 5.Plug the power cord into the back of the printer. 6.Press the On button to turn the printer on. 7.Install the ink cartridges when prompted. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Hi there This is only some thing you can try it may work. Good luck. Solution 1:
LONG DRAIN If the drain time exceeds 8 minutes the water valves turn off. NOTES: After 4 minutes the “Sd” error will be displayed, then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
